dav386 Member 29 Member For: 16y 9m 22d Gender: Male Location: Brisbane Posted 16/03/08 09:11 AM Share Posted 16/03/08 09:11 AM gday guys (and gurls)ive had a problem with the brakes on my turbo (mk1) ute for a while now.... when braking lightly, rolling (not driving) slowly down inclines my brakes make an awful noise and feel like that are slipping, but then grip soon after.. then the other day a camry cut me off, and when I broke heavy, I felt the same thing happen to the brakes again, but this time, after I continued driving, my abs warning light came on and stayed on. I was crapping myself cosi thought it would be some sort of abs thing that costs around $1000 to fix.. but after work I turned the car on and the warning was gone. Just wondering if anyone had the same/similar problems and know how to rectify it if possible. my mechanic (not ford) is a good guy and cant find a problem with it, so I am stumped.cheers guys Link to comment Share on other sites More sharing options...
XRPete Member 673 Member For: 17y 2m 3d Gender: Male Location: Here Posted 16/03/08 10:13 AM Share Posted 16/03/08 10:13 AM if a warning light came on it should show up a fault code on the ecu. Get that checked out Link to comment Share on other sites More sharing options...
ktm07 Member 42 Member For: 17y 1m 25d Gender: Male Location: Melbourne Posted 16/03/08 10:31 AM Share Posted 16/03/08 10:31 AM Hi Mate, I had a similar problem with my ute, it most likely will be an ABS sensor, or in my case a wheel bearing Link to comment Share on other sites More sharing options...
dav386 Member 29 Member For: 16y 9m 22d Gender: Male Location: Brisbane Posted 21/03/08 04:37 AM Author Share Posted 21/03/08 04:37 AM if a warning light came on it should show up a fault code on the ecu. Get that checked outthanx mate, I might go do that! Link to comment Share on other sites More sharing options...
dav386 Member 29 Member For: 16y 9m 22d Gender: Male Location: Brisbane Posted 21/03/08 04:38 AM Author Share Posted 21/03/08 04:38 AM Hi Mate, I had a similar problem with my ute, it most likely will be an ABS sensor, or in my case a wheel bearingthanx mate, that's also a new angle I can check on, I just hope it doesnt cost too much $$ to fix whatever it is Link to comment Share on other sites More sharing options...
