hamnzf6 Member 10 Member For: 18y 11m 17d Posted 15/03/08 04:35 AM Share Posted 15/03/08 04:35 AM 06 bf typhoon, zf 6spd, edited to 335rwkw, having problems making the 2nd-3rd gear change, in perf mode hits limiter and will not change up, have to reduce throttle and slips into 3rd, in tiptronic makes the shift but waits about half a second, feels like its in neutral then makes the shift, any ideas or advice?? Link to comment https://www.fordxr6turbo.com/forum/topic/43599-zf-problem/ Share on other sites More sharing options...
youngy Member 293 Member For: 19y 7m 27d Posted 15/03/08 06:45 AM Share Posted 15/03/08 06:45 AM (edited) Your clutch packs are worn out and due to the zf having speed sensors on the input and output of each cluster it limits the shift. Edited 15/03/08 09:34 AM by tab Link to comment https://www.fordxr6turbo.com/forum/topic/43599-zf-problem/#findComment-646118 Share on other sites More sharing options...
hamnzf6 Member 10 Member For: 18y 11m 17d Posted 15/03/08 07:00 AM Author Share Posted 15/03/08 07:00 AM bugger, anyone know of someone in NZ that can do the rebuild Link to comment https://www.fordxr6turbo.com/forum/topic/43599-zf-problem/#findComment-646128 Share on other sites More sharing options...
A300srt8 Member 507 Member For: 20y 4m 4d Posted 15/03/08 07:37 AM Share Posted 15/03/08 07:37 AM So how much for a rebuild? Link to comment https://www.fordxr6turbo.com/forum/topic/43599-zf-problem/#findComment-646139 Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 19y 4m 24d Gender: Male Location: Adelaide Posted 15/03/08 08:06 AM Share Posted 15/03/08 08:06 AM 3k at Modbury automatics Link to comment https://www.fordxr6turbo.com/forum/topic/43599-zf-problem/#findComment-646148 Share on other sites More sharing options...
