xr6t4life Member 129 Member For: 15y 9m 14d Gender: Male Location: Perth WA Posted 25/09/11 05:16 AM Share Posted 25/09/11 05:16 AM need some help I have gotten as far as taking the 4 bolts out and loosening the 2 that are fouled by the oil return line but it seems my exhaust housing is stuck solid onto the core of the turbo so far I have tried hitting it with a mallat wd40 trying to turn it but it just wont budge.sooo does any1 have any ideas or is it best to just give to my tuner to pull off as I dont know how how easy it is to break the fins if I smash it to hard with the hammer??sean Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1143803 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 20d Posted 13/10/11 10:09 PM Share Posted 13/10/11 10:09 PM Mine is the same mate, have a new housing to go on but stuffed if the old ones is coming off without a fight!!I didn't want to damage fins or bend the shaft so left it be for the mechanic who puts the new turbo on, to change my rear housing over.Apparently they require lots of heat, and then should just about drop off. Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1149081 Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 13y 9m 21d Gender: Male Location: Yeppoon qld Posted 15/10/11 02:04 AM Share Posted 15/10/11 02:04 AM This is probably a stupid question but is there supposed to be a gasket between the turbo and exhaust manifold? I'm guessing yes but dont remember seeing it when I pulled it off (was in a hurry to get the turbo to the shop though) and cant find the old one anywhere. Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1149598 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 20d Posted 15/10/11 02:29 AM Share Posted 15/10/11 02:29 AM They didn't come with one from the factory!!Put one in though when you put it back together. Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1149611 Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 13y 9m 21d Gender: Male Location: Yeppoon qld Posted 15/10/11 02:43 AM Share Posted 15/10/11 02:43 AM Damn! Should've looked here before I bolted it back on. Called ford and they said it didnt need one. Seems strange to me but oh well. Hopefully it's ok because I dont want to have to give them another $48 for studs. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1149612 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 6d Gender: Male Posted 03/08/13 01:41 PM Share Posted 03/08/13 01:41 PM Had a go at this myself this weekend and was a easy process that only took 6 hours or so with R&R of turbo and a few breaks. Has a obvious crack but that's no biggie and will be addressed in due course.Just used a Dremel/snake adaptor along with appropriate cutting/smoothing tools. Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1412636 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 2d Gender: Male Location: @ my laptop Posted 03/08/13 11:00 PM Share Posted 03/08/13 11:00 PM do not thinks it's going to work very well based on what I can see in your pics 1 Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1412673 Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 12y 6d Gender: Male Posted 03/08/13 11:48 PM Share Posted 03/08/13 11:48 PM It works fine...boost is lower now up top. Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1412687 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 29d Gender: Male Location: Adelaide Posted 04/08/13 12:49 AM Share Posted 04/08/13 12:49 AM Is that still the stock flap ? Looks like it or your welding skills are top notch Did u just take some of the excess boar out ? Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1412707 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 2d Gender: Male Location: @ my laptop Posted 04/08/13 01:44 AM Share Posted 04/08/13 01:44 AM boost up top is not an issue, it's mid range boost when a stronger actuator is used with a free flowing exhaust and intake.how about a pic of the flapper open and what size flapper did you use? 2 Link to comment https://www.fordxr6turbo.com/forum/topic/43547-removal-of-turbo-in-preperation-of-porting-and-valve-mod-part-ii/page/2/#findComment-1412717 Share on other sites More sharing options...
