  • Member For: 18y 1m 1d
I can't believe no one has mentioned the sirens :banghead:
  • Replies 107
  • Member For: 19y 8m 30d
So you mean, using the solar power to power the ancillaries like the alternator to power the drive belt, to add power to the engine?
Interesting... Although its starting to sound like a Falcon/Prius combination that way... Falus? Pricon?
  • 1 month later...
  • Member For: 17y 7m 2d
  R-SPEC said:
I'm talking unmarked. Anything that is regularly used in pursuit or in demand of possible high speed travel has wider tyres fitted and retains the stock hubcaps.
It's more difficult to spot on Falcons but Commodores are easy to spot.
Seriously, next time you see the lights in the back window of an unmarked Commodore, check out the width of the tyres!
Just to clear this up.
VT - VZ Commodores had 225/60 R15 as part of the "9C1" Police Pack. Standard size is 205/65 (looked good, but yeah easy to spot it as a Police car).
AU2 - BF Falcons had 215/55 R16 on Sedans and some wagons only.
The SS/XR8 tyres were the same as standard cars.
The VE Omega 9C1 pack appears to have the same size tyres on Police cars, as it is on the standard version.
  • Member For: 20y 9m 18d
WTF is it with people thinking cop cars are modded!?
THEIR STOCK!
other than a larger alternator and trans cooler they are STOCK!
STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK STOCK
