01txr Member 861 Member For: 18y 5m 17d Gender: Male Location: QLD Posted 12/12/10 03:28 PM Share Posted 12/12/10 03:28 PM Loose turbo nuts Don't know if anyone has yet suggested this as I have not read this tread through. Why not just use bolts instead. Drill hole through head perpendicular to shank and use lock wire to keep themTight. You just need to wire them correctly for it to work, bit hard to explain without a diagramSo if anyone really wants to know how to, pm me a email address and I will email you a diagram. Another option is to multi drill the nut and stud and use a cotter pin. As per old ball joints and stub axle nut retaining etc. Both of these are cheap options with the 1st bolt setup being the easiest and the 2nd needing to be precisely so holes align for pin. Link to comment https://www.fordxr6turbo.com/forum/topic/43254-loose-turbo-bolts-again-and-again/page/6/#findComment-1063153 Share on other sites More sharing options...
YOB POM Member 140 Member For: 20y 26d Gender: Male Location: Jimboomba Qld Posted 12/12/10 09:51 PM Share Posted 12/12/10 09:51 PM "What's an extension shaft with a slight wiggle on the end look like?"They're called a wobble extension,here's a pic http://sidchrome.com...es/AP/254_2.JPGNotice that the drive end is not square.It gives you a bit of movement and are a very handy tool.John. Link to comment https://www.fordxr6turbo.com/forum/topic/43254-loose-turbo-bolts-again-and-again/page/6/#findComment-1063170 Share on other sites More sharing options...
John_K Donating Members 438 Member For: 16y 6m 26d Gender: Male Location: Sydney Posted 12/12/10 10:49 PM Share Posted 12/12/10 10:49 PM Cool! Cheers John.I've never seen one of those before. Gonna go hunting! Link to comment https://www.fordxr6turbo.com/forum/topic/43254-loose-turbo-bolts-again-and-again/page/6/#findComment-1063178 Share on other sites More sharing options...
tim85 Member 56 Member For: 14y 11m Posted 12/12/10 11:20 PM Share Posted 12/12/10 11:20 PM Do it properly the first time and you won't have to worry about it ever again. Buy some Atomic Anchorlox and a flange gasket (as the T's don't come standard with a gasket!), take the turbo out and torque the studs up properly. This way you will not ever have to worry about these bolts coming undone. Link to comment https://www.fordxr6turbo.com/forum/topic/43254-loose-turbo-bolts-again-and-again/page/6/#findComment-1063187 Share on other sites More sharing options...
