BFHOON Donating Members 1,932 Member For: 19y 3m 6d Gender: Male Location: nsw Posted 04/03/08 05:43 AM Share Posted 04/03/08 05:43 AM I would say yes its a full reset.there may be a second chip not associated with tune holding memory such as times dates and other tid bits. Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-641645 Share on other sites More sharing options...
adamw Member 143 Member For: 20y 11m 15d Location: Darwin Posted 04/03/08 05:47 AM Author Share Posted 04/03/08 05:47 AM (edited) OK I must be having a bad day.. I'm not referring to the logs.To pose it in a simpler way:Let's say I have the ECU flashed with an 8psi tune. I flash it back to factory tune. Is it possible that there are still some remnants of the 8psi tune in the ECU - I.e. something to do with boost, fuel, timing that is not reverted fully back to its factory maps.There are only two possibilitiesa) I have a mechanical problem - I.e. fuel pump, filter, plugs, coil packs that is causing the pinging- nothing to do with the tune. This makes sense because it happens on the factory tune.b) I don't have a mechanical problem, but when I flash back from 8psi to factory, the factory settings are not completely being overwritten, it might still be running too much timing from the 8psi tune that was not reverted to factory completely. This would explain pinging even on the stock tune. I find this highly unlikely, but am just trying to gauge if it is at all a possibility - but obviously explaining myself poorly. Edited 04/03/08 05:50 AM by adamw Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-641647 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 23d Gender: Male Location: SW Sydney Posted 04/03/08 06:00 AM Share Posted 04/03/08 06:00 AM I'd go with a)As HOON said, it is a full re-flash back to factory settings Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-641648 Share on other sites More sharing options...
adamw Member 143 Member For: 20y 11m 15d Location: Darwin Posted 04/03/08 06:16 AM Author Share Posted 04/03/08 06:16 AM Thanks.. if that's the case I will have to hunt harder for this mechanical problem. Since it could be fuel pump related (although unlikely) I might have to push Ford to replace the pump with a new one (apparently BF2's came with a potentially faulty model?) Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-641653 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 23d Gender: Male Location: SW Sydney Posted 04/03/08 06:21 AM Share Posted 04/03/08 06:21 AM yeah, there has been a few instances of dodgy fuel pumps Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-641655 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 3m 6d Gender: Male Location: nsw Posted 04/03/08 07:31 AM Share Posted 04/03/08 07:31 AM id be looking at the crank angle sensor.throttle position sensor.fuel blockage as u said.possibly the solonoid wd40 job any vacum leaksblocked cat from added heat from the edit.bent rod, a bit extreme, hows the idle rough,theres so many things it could be, good luck mate I hope u find the problem.have a try at removing the battery over night. Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-641682 Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 11m 14d Gender: Male Location: Brisbane Posted 04/03/08 09:01 AM Share Posted 04/03/08 09:01 AM Mate in my case my car was originally tuned with a powerchip, now when I edited my car the powerchip tune beacme the F slot tune and what is refered to as the stock tune (which it is not).That cannot be overwritten or reset unless I go to Ford and get them to overwrite my ECU with a stock tune, and I loose a life on my edit box and start all over again.To answere your question, yes your car unmodified is pinging on a stiock tune, it is an issue and should be resolved by Ford, they will however try to get out of it.Scotty Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-641708 Share on other sites More sharing options...
adamw Member 143 Member For: 20y 11m 15d Location: Darwin Posted 07/03/08 07:34 AM Author Share Posted 07/03/08 07:34 AM So I took the car in today and got it back with the following comments"The calibration was wrong. It was calibrated for unleaded and now we've calibrated it for PULP".It sounds vague, and probably meaningless. It sounds like they did nothing? Anyone able to comment? Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-642988 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 5m Posted 07/03/08 11:03 AM Share Posted 07/03/08 11:03 AM If the calibration was set for unleaded their is no way it should ping if your using premium. If they have set it to pulp it would be more likely to ping now as the fuel and ignition tables would now be suited to the better fuel.Maybe you have just had a bad bunch of fuel which can take a few tank fulls to get rid of. Try disconnecting your battery for more than 10 mins to reset everything and try a different servo for 98 octane fuel. Link to comment https://www.fordxr6turbo.com/forum/topic/43239-reverting-to-a-factory-tune/page/2/#findComment-643069 Share on other sites More sharing options...
