Reverting To A Factory Tune
adamw
  • Member For: 20y 5m 30d
Hi All
When reverting to a factory tune from the stock tune, with no other mods, does the factory tune stored in the flash tuner COMPLETELY revert back to the stock tune. By this I mean are all fuel, boost and timing maps overwritten completely with the factory tune stored when you first perform a flash tune.
The reason I ask is I am getting some pinging at high RPM which I am investigating, but assumed it would be resolved by going back to the factory tune - thinking it was just too much boost/too hot/too much timing or something. I never had any pinging on the stock tune before flashing the car. However, it now pings even after reverting to the factory tune.
I am not looking to diagnose the pinging (I have a different thread for that and am changing plugs, fuel filter this weekend to see if that helps). I am just wondering if flashing it back to stock does a complete job or whether it possibly leaves some of the data in there that was altered by the flash tune, which would explain why the car could possibly be pinging even after running the stock tune again. I am guessing this is probably not the case and I need to be looking at other things as I am (fuel filter, fuel pump, plugs, coil packs etc.)
Car in question is a BF2 T
Adam
Sorry maybe my question was not clear - I'm not thinking the factory slot was overwritten - I was thinking when flashing the car back to factory is it possible it doesn't revert ALL data in the ECU back to stock, and leaves some things in their altered state?
They're guessing that it has been flashed if that's the case. A counter saying how many times it has been flashed doesn't say much - I didn't buy the car from the local dealer. The dealer I bought it from may have reflashed it with updates a few times.
Edited by adamw
  • Forged Member
  • Member For: 17y 11m 7d
apparently the BF2's will log what has been changed, so if the boost has been changed, they will know that you have been having fun!
I think any reputable tuner would be able to see that data, and since it is alterable (I.e. it is logging what has changed), the tuner would also be able to alter it to remove that.
Would be interesting to know for sure - its the sort of thing lots of myths are likely to come out of.
Either way it pings on the factory tune with no mods - I don't think it is unreasonable that they try and diagnose it.
  • Member For: 18y 9m 21d
the f slot has the factory tune and is only loaded once into the box on the first use of the flash box.
if you want to add new data to the f slot you need to reset the flash box and loose one life.
if you had a car that had a performance tune in it and the box was not sold with the car, when you put on a new flashbox it will load the perfoemance tune into the f slot.
the f slot dosnt do what your saying it wont hold any old settings in it.
I know what the F slot holds.. it holds the factory tune, downloaded the first time you reflash the car using one of the tunes on the box.
What I'm saying is, the data that is held in the F slot.. is it complete? I.e. When you reflash the car with say, an 8psi tune, and then revert back to the factory tune (by reflashing the car from the F slot), does it completely overwrite everything in the ECU that the 8psi tune changed?
