jbute Member 95 Member For: 18y 1m 30d Location: NSW Posted 03/03/08 12:46 PM Share Posted 03/03/08 12:46 PM Have a BF mk2 XR6T 6sp man 20k & lately when it is cold it is fine as soon as it warms up it is shaking all over the joint & feel like a miss. The good chaps at my local dealership have replaced coils, spark plugs & the newest software but there computer is not working at the moment to do any tests.When it is warm & I give it some between 3500-5200 it surges & just doesn't feel right then when I pull up it idles really rough.I picked it up from the dealship cold & I thought yes they have fixed when but the engine warmed up I give it a bit then it was idling rough all the time agian.When I put on the A/C at idle it makes a knocking nice my heart dropped the first time I heard it till I workrd out that it goes away when turning of the A/C.Coil Drivers ?Valve Spring ?Thanks ! Link to comment https://www.fordxr6turbo.com/forum/topic/43223-how-to-tell-when-valve-spring-are-going/ Share on other sites More sharing options...
jared87 Member 85 Member For: 17y 1m 21d Gender: Male Location: Gympie Posted 19/03/08 07:51 AM Share Posted 19/03/08 07:51 AM Im taking a lot of intersest in this topic my BA does the same and is down on power in a big way whether its on standard tune or 10 psi. Mine is in getting the springs fitted right now and I am picking it up tomorrow so I will let you know if it fixes the problem, im really really really hoping so. Link to comment https://www.fordxr6turbo.com/forum/topic/43223-how-to-tell-when-valve-spring-are-going/#findComment-647717 Share on other sites More sharing options...
adzza17 Member 103 Member For: 18y 5m 27d Gender: Male Location: Sydney Posted 19/03/08 09:47 AM Share Posted 19/03/08 09:47 AM I could tell mine were soft and needed changing when I'd give it a bootfull then slow down and stop at lights, the car would run like sh*t and idle really rough almost to the point of it stalling, then after a few seconds it would go back to normal idle Got some nizpro's fitted and doesn't happen anymore Link to comment https://www.fordxr6turbo.com/forum/topic/43223-how-to-tell-when-valve-spring-are-going/#findComment-647788 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 2m 18d Posted 19/03/08 10:03 AM Share Posted 19/03/08 10:03 AM Sounds very familiar to a typhoon and a territory,both which we had in to the dealership in the same week. They both had rough idle when warm,the typhoon was down on power and was surging and when the problem occured they both sounded like they had performance cams. After several hours doing the usuall checks and tests we found the cam timing had jumped a tooth on the crank. We have never seen this problem before and then 2 in 1 week. Neither of them had any engine work or mods previously and had done about 30,000km. Suggest it to your dealer if they get stuck and cant find problem. Link to comment https://www.fordxr6turbo.com/forum/topic/43223-how-to-tell-when-valve-spring-are-going/#findComment-647797 Share on other sites More sharing options...
jared87 Member 85 Member For: 17y 1m 21d Gender: Male Location: Gympie Posted 20/03/08 10:57 PM Share Posted 20/03/08 10:57 PM I had my nizpro springs fitted yesterday and it has made a difference the idle is not as rough and it seems to have a little bit more power, well probably torque. In saying this I still get a bit of pop coming from the exhaust and not a perfect idle so I do not believe I have got to the bottom of this problem yet, im starting to get really annoyed reading how everyone else has so much power with ease but I cant seem to get it. Link to comment https://www.fordxr6turbo.com/forum/topic/43223-how-to-tell-when-valve-spring-are-going/#findComment-648464 Share on other sites More sharing options...
jared87 Member 85 Member For: 17y 1m 21d Gender: Male Location: Gympie Posted 21/03/08 01:44 AM Share Posted 21/03/08 01:44 AM Did I see in another topic somewhere that a problem like this could also be the fuel pump?? Link to comment https://www.fordxr6turbo.com/forum/topic/43223-how-to-tell-when-valve-spring-are-going/#findComment-648518 Share on other sites More sharing options...
chooch Member 256 Member For: 21y 2m 14d Location: Adelaide Posted 21/03/08 02:58 AM Share Posted 21/03/08 02:58 AM My valve springs died a few months go and were replaced $800. Symptoms included missing at high rev's. I think some people might call it surging or pinging, I'm not to sure but when the rev's hit about 4500 the motor would miss. It didnt have any problems idling. valve springs fixed it. Link to comment https://www.fordxr6turbo.com/forum/topic/43223-how-to-tell-when-valve-spring-are-going/#findComment-648545 Share on other sites More sharing options...
