Wenier Donating Members 1,736 Member For: 15y 3m 2d Gender: Male Location: Christchurch, New Zealand Posted 22/10/11 05:49 AM Share Posted 22/10/11 05:49 AM Well first check would be battery voltage to make sure that is alright. Another simple step would be disconnect the battery leave it off for 5-10mins then connect back up and see if that makes any difference.Start with all the free and cheap things. Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1152515 Share on other sites More sharing options...
Jimbob Member 148 Member For: 18y 1d Gender: Male Location: Melbourne Posted 22/10/11 05:58 AM Share Posted 22/10/11 05:58 AM Now that I think about it you may have hit the nail on the head with the battery I looked up when I bought and its almost 3 years old mix that with the fact the car has not been run for 3 weeks we may have a winner. either way I think I should get a new battery so im going to give that a shot and if that does not work ill recheck everything I have done for the second time and if its still not working ill come back on hear and :cry: about it Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1152517 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 4d Gender: Male Posted 01/02/12 09:31 PM Share Posted 01/02/12 09:31 PM I bought some inconel studs and stage 8 nuts. I took all the heat shields off but it seems like you can't replace the studs with these ones (slightly too long) with the turbo and manifold still in place. I think it will all have to come out, which means a Saturday job, not a 9pm at night job :( Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1189662 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 8m 10d Gender: Male Posted 11/07/12 02:06 PM Share Posted 11/07/12 02:06 PM Is it hard to fit the stage 8 fasteners while the turbo is attached?Mine is removed with the manifold but I see you can't fit the bottom two studs and fasteners while it's out as the turbo bracket needs to be bolted inbetween. Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1266062 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 10d Posted 12/07/12 03:18 AM Share Posted 12/07/12 03:18 AM Maybe remove the bracket and manifold, assemble it all, then refit turbo, manifold and bracket as one? Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1266268 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 8m 10d Gender: Male Posted 12/07/12 04:51 AM Share Posted 12/07/12 04:51 AM Yeah was thinking of that, will have to look and see if the bracket is easily removable :( Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1266310 Share on other sites More sharing options...
Haydo83 Member 17 Member For: 12y 10m 10d Gender: Male Location: Newcastle NSW Posted 21/08/12 01:17 PM Share Posted 21/08/12 01:17 PM Hey.Can anyone give me any helpful tips on getting the clip back on the wastegate arm for the actuator.Just replaced my actuator as I think that was brrrrr problem,took me ages to get the clip off cos its in such a sh*t spot,couldnt get the clip back on so I had to put it all back together to get to work and now the actautor has popped off the arm so now ive got no boost :( any hints would be much apprectiated Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1282698 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 20d Gender: Male Location: Adelaide Posted 21/08/12 09:47 PM Share Posted 21/08/12 09:47 PM Bud do it from under the car much easier Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1282755 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 28d Gender: Male Location: Perth Posted 21/08/12 11:38 PM Share Posted 21/08/12 11:38 PM easiest way to refit the clip on the car is to remove the dump pipe and as Jetters said, do it from under the car. Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1282801 Share on other sites More sharing options...
Haydo83 Member 17 Member For: 12y 10m 10d Gender: Male Location: Newcastle NSW Posted 22/08/12 11:58 AM Share Posted 22/08/12 11:58 AM Hey.thanx for the advice guys me and a mate spent all arvo trying to get at it and we lost a few c clips in the process and managed to get a hair clip in it lol for a few klms before she popped off.got a gasket kit on its way so il pull that dump pipe out then should be a peice of cake. Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/6/#findComment-1283420 Share on other sites More sharing options...
