mic Donating Members 1,725 Member For: 17y 2m 28d Gender: Male Posted 26/06/08 06:16 AM Share Posted 26/06/08 06:16 AM has anyone actually changed the actuator without taking the turbo off ? I think its impossible. Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-698581 Share on other sites More sharing options...
smarty Member 37 Member For: 17y 9m 22d Gender: Male Location: Adelaide Posted 26/06/08 11:55 AM Share Posted 26/06/08 11:55 AM yes I have , if you have a lot of patients and about 1 & 1/2 hours , it can be done without removing turbo p.s a hoist would be the go Smarty Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-698763 Share on other sites More sharing options...
xr6t ego Member 1,112 Member For: 18y 3m 22d Gender: Male Location: PERTH WA Posted 26/06/08 11:59 AM Share Posted 26/06/08 11:59 AM Great post mrmackie and headsex for the added tips. These are the sort of threads that make this site such a great place. It gives some of us novices an idea of how to attempt to fix and fiddle with our cars. Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-698766 Share on other sites More sharing options...
XRforced Member 14 Member For: 16y 9m 18d Gender: Male Location: Rockhampton Qld Posted 30/06/08 11:14 AM Share Posted 30/06/08 11:14 AM hey just had a few questions for ya's, I have just has the 12 actuator installed and had the waste gate machined and larger flapperjust asking around and the people I know with xr6t's have not done this mod eventhough they have installed exhaust's intercoolers custom tunes I would have thought this would be one of the first mods, as to avoid overboost/boost spiking when running higher boost spressures, because they only have a 5.9psi wastegate standardand it was for the reason that I was getting over boost, like with the 8spi/10psi Capa flash tune it was spiking up to like 13psi at times.so just wondering is this a common modification and do you all had this done? Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-700387 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 10m 26d Gender: Male Location: Sydney NSW Posted 30/06/08 12:51 PM Share Posted 30/06/08 12:51 PM Alot of poeple dont do any mods to the turbo ad get ok boost control, other get massive spikes.There's lots of tuners that tune differently and can control boost where others can't / havnt try'd or bothered.Best thing to do is go with your chosen tuners advise, as he will decide the end result... some wont tune without the mods being done, others are happy to and get good results.Boost control and behavior is also greatly effected by the flow of air into and out of the motor, which is why some guys have HAD to do the mod, and others are happy to see a few psi up or down. Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-700443 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 18d Gender: Male Location: Canning Vale, W.A Posted 30/06/08 01:04 PM Share Posted 30/06/08 01:04 PM I'd recommend doing it, car feels heaps better Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-700445 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 5m 7d Gender: Male Location: Perth, NOR Posted 01/09/08 11:36 AM Share Posted 01/09/08 11:36 AM (edited) I've removed all the banjo fittings, dump pipe bolts, coolant tank + pipes...etc its all out of the way. All that is left is to remove the 3 (1 has fallen off while driving) bolts holding the turbo to the manifold. BUT I cannot for the life of me undo the bolts on the manifold/turbo. I feel that if I try any more it will round the nut. I've tried about 5 different size 14 ring spanners (all are the 12 point type, as I can't find/buy a 6 point ring spanner anywhere) and I'm using the one which grips the best - they all have a bit of play in it.I've tried using WD40, heat on the nut and neither helps.So my question is, would it be okay for me to remove the manifold with the turbo still attached, and lift the manifold + turbo out of the engine bay together. Or do you recommend NOT taking off the exhaust manifold from the engine? All of those bolts can be easily cracked and removed. Edited 01/09/08 11:37 AM by XF Falcon Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-726704 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 5m 7d Gender: Male Location: Perth, NOR Posted 01/09/08 04:36 PM Share Posted 01/09/08 04:36 PM Never mind I got the bolts off in the end, oh and the manifold is off too. Spewing, I should really buy a new exhaust manifold gasket now shouldn't I? Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-726777 Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 2m 28d Gender: Male Posted 02/09/08 07:26 AM Share Posted 02/09/08 07:26 AM yes get a new gasket, definately. I had 2 take my maifold off with the turbo cause there was 1 bolt fused, and had 2 weld a bolt on top 2 get the nut out. Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-727000 Share on other sites More sharing options...
civillian Donating Members 78 Member For: 20y 6m 29d Gender: Male Location: Canberra Posted 25/09/08 01:14 PM Share Posted 25/09/08 01:14 PM XF Falcon said: Never mind I got the bolts off in the end, oh and the manifold is off too. Spewing, I should really buy a new exhaust manifold gasket now shouldn't I?Nice write up mrmackie, you make it look easy which is why I gave it a go...well...XF Falcon: How did you get the last nut/bolt off?? This is the one I'm stuck on right now...I've got every nut off... dump pipe was easy, so was the other 3 turbo-to-manifold ones, except the one you pictured above. I think I've rounded the nut a bit I have 2 questions for you or anyone here1) How should I get the rounded nut off, considering access is poor? (dont care if it dies in the process)2) In my BA mk 1, I have studs for the turbo to dump pipe assembly, as well as the turbo to maifold, how do I get studs out without damaging them?? Link to comment https://www.fordxr6turbo.com/forum/topic/43162-removal-of-turbo-in-preperation-of-porting-and-valve-mod/page/2/#findComment-740225 Share on other sites More sharing options...
