What Is The Offset Of Wheels For Falcon
cobrav8
  • Member For: 19y 10m 26d
Stud pattern - 5 X 114.5
Offset is positive 36
So is that stud pattern really .02mm different - or is there some rounding? The Offset - would that mean that the wheels would stick inward too far and hit the top suspension arm - or stick out slightly further? Would they fit?
  • Member For: 19y 13d
Falcon stud pattern is 5 x 114.3 pcd (pitch circle diameter)
Offset for AU-BF sedans is +36, so +38 is a tiny difference that means they will be wider inwards (towards the brake disc) by 2ml.
Just remembered, check the centre hole diameter. You may need a fitting ring to make them hub-centric (they should sit on the centre ring for support, not on the studs). I can't remember the standard centre diameter.
  • Dr. Speed
  • Member For: 17y 6m 18d
  • Location: The land of Politicians, Public Servants, Porno & Pyrotechnics
Whoops - sorry that meant to read 5 X 114.3 :censored:
I reckon those wheels would fit fine. They are only 18 x 8.5's and the offset should be ok.
I have 20 x 8.5 on the front and they don't scrub or rub on anything. Not sure of the offset however.
  • 2 weeks later...
  • rob327
  • Member For: 16y 11m 6d
I didnt think to check forums, but I got 18 x 8s with a 35 offset because I was worried the 8.5s wouldnt fit given the sfa clearance on the inside
  • Member For: 19y 7m 11d
+38 with 20x8.5 have rubbed (front) on one xr6t and not on another.....I think it's touch and go. Best sticking with a +35 (with 8.5" wide rim) offset for the front as these are common and fit fine.
