  • Member For: 19y 10m 4d
  MICKAJ said:
So can you edit the tunes on the flasher or are they set in stone. Say I wanted some mods like exhaust, cooler 12 PSI could a tune be made using the Capa then flashed into the car?
Also like a virgin is there any way to tell that the car has been flashed and hence void warranty?
If you are planning those mods, you'll need to budget for a new clutch and in time a 6 speed gearbox as the 5 speed will suffer.
  • Member For: 19y 1m 22d
getting to instructions.
reds off plug in the box to the plug near the fusebox.
select p1 p2 or p3 with the select button and press the program button.
once the box starts flashing turn on the reds and wait till the program light holds a solid on light.
the f slot has your factory tune in it and must be replaced before ford look at the car.
your car may have a custom tune already installed but as the others have said you may have generic tunes loaded in the box.
the edit cant remove km`s from the odometer.
