  • Member For: 21y 6m 11d
Gday Lads, have picked up some new wheels for the phoon…….these are Work Emotion CR Kai (made in Japan) which weigh 9.5kgs a wheel less than the standard R Spec 19s….I really like the race look of these and the huge saving in unsprung weight is noticeable!
Plenty of calliper – spoke clearance however only 3-4mm at top and bottom of calliper to wheel (inboard). Good thing they are strong as. Size 18x8.5 +30.
Cheers
Rob
https://www.fordxr6turbo.com/forum/topic/42957-new-wheels-for-the-r-spec/
  • Replies 54
  • Member For: 17y 10m 18d
Would look awsome if they were 19's, 18's are too small. Great choice though :beerchug:
  • You are a dead set goose
  • Member For: 19y 4m 14d
Looks great mate. My Accord has 17" Prodrive rims on it and people say they look a bit small, but it makes it look more like a track car than a show car. Looks tough!
These are made by Prodrive and are 6.8kgs each...
  • <put funny sh*t here>
  • Member For: 18y 5m 5d
Did you notice its easier to brake or anything like that?
I'm not sure if it was due to weight or the increased rolling diameter, but when I went from stock 17" to the 19" wheels the first time I put on the brakes I really noticed it needs a lot more brake force to stop.
Yep, that's the angle...I am not into the flash look, rather I am trying to turn this car into the R (for race) SPEC that FPV should have released. I didnt want to run 19's for these reasons -
1. Poor selection of Semi Comp rubber in 19'
2. 35 profile is a dud for performance - need a bit of sidewall
3. Additional unsprung weight
Des - no mate, not really. I wanted to keep the same front / rear footprint (at the moment the car already is prone to high speed understeer.......add more rear grip = more understeer) and the 250-260rwkw that I will be running will be ok with 245 semis comps.....and I want to be able to rotate them.
that's the extra unsprung weight mate. The affect of unsprung vs sprung weight on the cars suspension / braking is 4 to 1.
And yes, there is definately a notable improvement, you can feel the suspension isnt working so hard and the ride is definately improved. No chance to test the brakes yet though.
  • Forged Member
  • Member For: 18y 2m 6d
Still can't go past Work wheels for the ultimate tract weapon look! Did you consider TE37s Rob?
