Typhoon Member 564 Member For: 20y 7m 24d Gender: Male Posted 20/02/08 09:38 AM Share Posted 20/02/08 09:38 AM Hi guys;I really think I need to service my ZF 6 speed. I was wondering why you need to replace the sump on the ZF when servicing it. Can’t I just flush the box and put new oil in it? How much does the sump cost to replace and is it necessary is my question. Also I think I will just put the factory oil back in it and not the Tranzmax Z. Your thoughts?The reason I think it needs to be serviced is its flaring out in performance mode and seams to be slipping at WOT. In manual mode it does not seam as bad and dose shift fairly well.The car has been modified since 2500kms and now has 18000 on it. The ZF still has the factory oil in it.I have searched the site and have found info on the oil type but not much info on the sump it self.Any advise is appreciated Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/ Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 5m 17d Gender: Male Location: Brisbane Posted 20/02/08 09:52 AM Share Posted 20/02/08 09:52 AM I've had mine changed too. I can't remember how much it costed though sorry. Be prepared to be up for a bit though as the oil from memory costs around $50 a litre!!! Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636506 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 7m 24d Gender: Male Posted 20/02/08 09:55 AM Author Share Posted 20/02/08 09:55 AM EZ2CME said: I've had mine changed too. I can't remember how much it costed though sorry. Be prepared to be up for a bit though as the oil from memory costs around $50 a litre!!!Thanks.Why did you have to change it? Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636510 Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 5m 17d Gender: Male Location: Brisbane Posted 20/02/08 09:57 AM Share Posted 20/02/08 09:57 AM I've had the car modded since about 8000kms and thought it might be a good idea. Was told the oil that came out of it was still in pretty good nick and looked good though. Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636515 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 10d Gender: Male Location: SW Sydney Posted 20/02/08 10:06 AM Share Posted 20/02/08 10:06 AM the ZF boxs are a *beep* to change the oil on. The oil has to be added at certain temperatures, you can't just fill it up to the top all at once for some reason - the boys in service hate doing it because it takes forever compared to the old BTR Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636522 Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 19y 5m 12d Gender: Male Location: Adelaide Posted 20/02/08 10:12 AM Share Posted 20/02/08 10:12 AM f6tornado is the guru so hope he sees this,I have been trying to find someone in sa to do this to as mine is a bit flary to,I think the filter is in the sump and they block and apparently the transmax helps stop flaring we may be able to get a deal on 2 services Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636525 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 7m 24d Gender: Male Posted 20/02/08 10:15 AM Author Share Posted 20/02/08 10:15 AM (edited) bloosted said: f6tornado is the guru so hope he sees this,I have been trying to find someone in sa to do this to as mine is a bit flary to,I think the filter is in the sump and they block and apparently the transmax helps stop flaring we may be able to get a deal on 2 services I have found a trans guy in S.A on good advice from my tunner.He spoke to him today and told me he had done them before.I just need to call him and find out what his thought on the sump are.Price wise he said around $650 to $700As for a discount on two we may be able to get $50 each off.I will let you know in the next two weeks ok? Edited 20/02/08 10:18 AM by Typhoon Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636527 Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 19y 5m 12d Gender: Male Location: Adelaide Posted 20/02/08 10:21 AM Share Posted 20/02/08 10:21 AM no probs I'm going to do the transmax so should be a bit cheaper Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636531 Share on other sites More sharing options...
F6BF Member 438 Member For: 19y 5m 5d Location: Sydney Posted 20/02/08 01:12 PM Share Posted 20/02/08 01:12 PM Sump and filter assy can be bought from here http://www.motospecs.com.au/atp.phpThey have a branch in every statePart no. ZXF-626005 - retail $199 and trade $119Castrol transmax Z can be bought from Repco $50-$60 for 4 litresU will need 5 to 5.5 litres for the serviceHTH Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636594 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 7m 24d Gender: Male Posted 20/02/08 01:20 PM Author Share Posted 20/02/08 01:20 PM F6BF said: Sump and filter assy can be bought from here http://www.motospecs.com.au/atp.phpThey have a branch in every statePart no. ZXF-626005 - retail $199 and trade $119Castrol transmax Z can be bought from Repco $50-$60 for 4 litresU will need 5 to 5.5 litres for the serviceHTHThank you very much for your help F6BF. Link to comment https://www.fordxr6turbo.com/forum/topic/42833-zf-6-speed-service/#findComment-636599 Share on other sites More sharing options...
