  • Member For: 14y 4m 20d
Your Name: Sean
Car Make and Model: FG mkII XR6T Manual
Circuit Name: Wakefield Park
Lap time: 1-13:8
Modifications: Bosch 1000cc Injectors, PWR Stage 1 Intercooler, Venom Cat, Ported Wastegate, Tune
Engine: 4.0T
Power: A very safe and linear 287rwkw on a conservative dyno
Suspension: Stock
Tyres: Fronts Michelin PS4S, Rears Worn Nitto NT05's
Brakes: QFM A1RM's. Motul RBF600. Calipers and discs standard
Body weight: Standard Weight
Had some fun out at the 'Park on Anzac day. Was really happy with my time considering stock suspension and mostly stock brakes.
Downside - had the dreaded overheating. After a few hotlaps coolant temp would get up to about 116-117c. A cool down lap would bring it down to 100c but I definitely need to get this sorted before the next session. Thinking I'll also get an oil cooler and oil temp guage for peace of mind next time.
Also thinking of getting some coilovers. Tossing up between Shockworks and MCA Reds. Are the MCA's worth the extra $1k? Bearing in mind the car is the family car the other 98% of the time, I'd still like to keep it relatively compliant as a daily.
  • To Loud
  • Member For: 13y 6m 2d
I have an FG XR6T manual and run Shockworks. As a family car it does the job, however there are often complaints about the ride.
I have the fronts at 4 clicks and the rears at 3 clicks, which is soft as far as I am aware.
However the car handles bloody well. I wouldn't swap it for anything else.
That feeling you get when you can place the car in the turn and at the apex every time with easy is hard to describe.
I can't comment on the MCA reds, but I definitely think that the Shockworks are worth it.
Thanks again Stripes.
  • Dropping a turd
  • Member For: 17y 7m 5d
  On 30/04/2018 at 8:48 AM, sd1800 said:
Your Name: Sean
Lap time: 1-13:8
Engine: 4.0T
Suspension: Stock
Expand
You need to start with a cooler thermostat.  Have the fans adjusted in the tune.
Install a thicker radiator and a look large engine oil cooler.
  • To Loud
really?
My car was transformed when I got the shockworks installed.
It no longer was a BARGE. No more under steer.
I personally don't believe that it is overkill. each person's wallet has different size.
You wallet could say it is over kill, while Arron's might not.
All I know is that when I want the car to turn, it just does.
  • WOT?
  • Moderating Team
  • Member For: 12y 3m 7d
Made mine into exactly what I was after.
Sure you're not confusing "hard suspension" with "handles well"?
It's not compulsory to feel every bump for a car to handle awesome.
What trouble did you have with the setup?
  • WOT?
  • Moderating Team
Nah, sorry - was to this (maybe I took his "soft as" the wrong way - as a criticism)
  On 03/05/2018 at 10:25 AM, OZYWALKER said:
Shockworks are soft as, surprised not many think so.
Expand
