  • The Cleaning Dudes Ute
  • Member For: 19y 21d
Giday guys,
A couple of weeks ago I had my T dyno'd, only mods are wa*ker mods like pod filter and blow off valve.
First run came up with 227rwkw's.
Second came up with 230.8rwkw's
Does this sound a bit high???
Heres a graph
Jarrod.
:stupid:
P.S.
Ill upload a vid when I can figure it all out...
https://www.fordxr6turbo.com/forum/topic/42656-had-my-stock-bf-xr6t-dynod/
  • Replies 29
  • Member For: 20y 11m 6d
I think you will find the answer if you look at the air temp compared to the inlet air temp, have them the same , and your car should have normal xr6t power.
David
  • Member For: 17y 11m 7d
that's awsome Jman you gotta be happy with that, good blank canvas to start off with.
  • Member For: 18y 11m 6d
David
With the air intake probe placed in the correct position, you will find that you probably will have maybe 200 ish rwkw
  • Member For: 17y 8m 20d
my T made 229rwkw when I got it onto the dyno a few weeks ago; I was shocked but it also explained why it was doing 13.74 stock down the 1/4
I swear these things are tuned better than they are advertised (particularly the BF's)
  • FG Falcon fan!
  • Member For: 21y 9m 27d
sounds like BF MkIIs are getting Typhoon-like engines minus the larger intercooler!?!?!?
I hear they have the same conrods now, perhaps the factory boost settings for the 'phoon come with XR6Ts from the factory now?
Im going to guess the XR6T comes with 270kW on Orion day next week.
  • Member For: 19y 8m 22d
as mentioned before.. IT in at the bottom of the dyno sheet.. "INTAKE TEMP".. 86 degree's C is a little high, and obviously pushing the dyno correction way out..
