Territory Turbo Pcd And Offset Question
explicit
  • Member For: 17y 9d
Hi guys, new to the forum.
Im in the throes of ordering an F6X.
First thing I want to do is get some decent wheels and rubber for it.
Can anyone tell me the offset and pcd of the factory 18" wheels?
any info appreciated.
Jme
  • Member For: 19y 7m 2d
Jme
Dude,
Im pretty sure that the PCD is the same as current Falcon 5 x 120mm, as for offset Im not sure. Ive looked at our TTG and it "seems" like the factory 18's may fit over the big brakes fitted to F6x.
Whatever wheels you choose, make sure they have a load rating at least equal to the factory wheel, for safety and insurance purposes. The Territorys are heavy beasts. Hope this helps.
Mal K
  • Dr. Speed
  • Member For: 17y 6m 19d
  • Location: The land of Politicians, Public Servants, Porno & Pyrotechnics
Dude,
Isn't the Falcon stud pattern 5 x 114.3mm......? and 36.5 positive offset on 17x8 wheels. No idea for the TT/F6X however.
Edited by exarsixturbo
Sorry dudes,
Was in old skool mode, that PCD applies to the prehistoric Falcon.... Just showing my age that's all... he he he.. If all fails check with a wheel manufacturer and buy from someone good and proven such as Simmons Wheels etc, not a crap ass Indo wheel maker, melting down a few frypans and coke cans... Have seen a few examples crack from normal use and one explode during motorsport use... All of a sudden that bargain basement wheel wasnt so cheap...!
  • 2 weeks later...
  • Member For: 22y 4m 9d
Sorry dudes,
Was in old skool mode, that PCD (5x120mm) applies to the prehistoric Falcon....
5 x 120mm is a metric (Commodore) size so I don't understand how it would by old skool.
Falcons have always been 5 x 4.5" (114.3mm), only the centre bore size and offset have changed.
That offset (+ve 36.5mm) is correct for the standard Territory 7.5" wide wheels (all the 17" & 18" ones from the factory)
  • 2 weeks later...
  • Member For: 16y 11m 5d
So if the stud pattern is the same as the Falcons can I get any wheels (obviously with tyres to suit the Territory) that would fit a Falcon? I'm assuming the Territory Turbo has the same stud pattern as the rest of the Territory's.
  • Member For: 17y 11m 3d
In theory yes.
However Territory wheels have a higher load rating than falcons.
