jcooke Member 272 Member For: 18y 7m 12d Gender: Male Location: Brisbane, QLD Posted 11/02/08 12:03 PM Share Posted 11/02/08 12:03 PM (edited) Hey guys (and girls ofcourse),When everybody talks about hooking up DVD players / MediaPC's to the ICC via RGB, is there actually an RGB connector on the screen or is a converter required? Has it something to do with that free plug on the buttom right hand side of the ICC? If so how do you switch inputs?ThanksP.s. looking at something along these lines, it comes standard with rgb out http://minipc.aopen.com/Global/spec.htm Edited 11/02/08 12:12 PM by jcooke Link to comment https://www.fordxr6turbo.com/forum/topic/42572-carputer-plug-into-icc/ Share on other sites More sharing options...
jcooke Member 272 Member For: 18y 7m 12d Gender: Male Location: Brisbane, QLD Posted 14/02/08 12:02 AM Author Share Posted 14/02/08 12:02 AM nobody? jeees tough crowd. Link to comment https://www.fordxr6turbo.com/forum/topic/42572-carputer-plug-into-icc/#findComment-634030 Share on other sites More sharing options...
Guest newl Guests Posted 14/02/08 01:32 AM Share Posted 14/02/08 01:32 AM Might find what you're looking for here:http://www.fordxr6turbo.com/forum/index.ph...amp;hl=carputerhttp://www.fordxr6turbo.com/forum/index.ph...amp;hl=carputerbut more than likely here:http://www.fordxr6turbo.com/forum/index.ph...amp;hl=carputer Link to comment https://www.fordxr6turbo.com/forum/topic/42572-carputer-plug-into-icc/#findComment-634061 Share on other sites More sharing options...
bogan393 Member 77 Member For: 18y 10m 18d Posted 16/02/08 09:48 PM Share Posted 16/02/08 09:48 PM for most applications a rgb converter is required, however if you are looking at running a car pc and your mobo has a agp slot then you can purchase a arcade vga graphics card that will connect straight up to the icc, this is what I was running in my car pc and it worked a treat. Link to comment https://www.fordxr6turbo.com/forum/topic/42572-carputer-plug-into-icc/#findComment-635079 Share on other sites More sharing options...
