Stereo Upgrade
chalkie
  • Member For: 17y 7m 2d
So you took your signal from the front speaker wires, which then went into the Line Converter. This line converter had RCA's for your front speakers and your Sub too?
So is it a monoblock/bridged seperate amp just for your sub? or did you use like a 4 channel amp (2 for the fronts and 2 bridged for the sub?).
what did you do with the standard factory amp and all the wiring which went to that.
I have just unpluged the original amp. Yes I used the front speaker wires straight out of the head unit to lc6, from there to a 4 channel alpine pdx amp to run front speakers and sub in 3 channel config. It sounds great.
Chalkie.
