Guest EGOXRT Guests Posted 06/02/08 10:58 PM Share Posted 06/02/08 10:58 PM Who ever did the job last over adjusted them, they got hot and have bound themselves to the drum. You are going to have to remove the rubber grommet on the disc and slacken the adjusters then bash.. Link to comment https://www.fordxr6turbo.com/forum/topic/42436-hand-brake-stuck-on/page/2/#findComment-631201 Share on other sites More sharing options...
jcooke Member 272 Member For: 18y 8m 15d Gender: Male Location: Brisbane, QLD Posted 06/02/08 11:51 PM Author Share Posted 06/02/08 11:51 PM so when I pull that rubber grommet off and look in the whole, I see a little gap in between what look like to half shoes. I assume these are the hbs? Do I need to split them further apart with a large screw driver and get mr mallet out?Thanks again for the replies. Link to comment https://www.fordxr6turbo.com/forum/topic/42436-hand-brake-stuck-on/page/2/#findComment-631212 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 9m 10d Gender: Male Location: Southern Highlands NSW Posted 07/02/08 02:59 AM Share Posted 07/02/08 02:59 AM IF you can get the rotor to rotate there is a little inspection hole that had a grommet. Make sure the rotor is sitting flush and not at an angle. You need to move the rotor so the hole is down the bottom. Now you will need a torch to look through the hole as you rotate the hole ever so slowly towards the back. You will need a hand brake tool to fix it. If I remember correctly to de adjust on the driver side you have to rotate the little wheel inside the drum away from you. Its a *beep* of a job and as ive done it so many times takes me about half an hour to do both side You can use WD40 to try and help but you will have to throw the old shoes away. Link to comment https://www.fordxr6turbo.com/forum/topic/42436-hand-brake-stuck-on/page/2/#findComment-631264 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 21d Gender: Male Location: Brisbane Posted 10/02/08 01:23 AM Share Posted 10/02/08 01:23 AM How did you get on? Set fire to the farker? Link to comment https://www.fordxr6turbo.com/forum/topic/42436-hand-brake-stuck-on/page/2/#findComment-632367 Share on other sites More sharing options...
jcooke Member 272 Member For: 18y 8m 15d Gender: Male Location: Brisbane, QLD Posted 11/02/08 11:36 AM Author Share Posted 11/02/08 11:36 AM well, long story short, stuck hand brake + sledge hammer (not hammer, not mallet, but sledgey) = released hand brake. We managed to get the shoes free however the disc still wouldnt come off. It did however mean that we could put it back together and drive the car to Paul at Elite for its scheduled service. They confirmed that it was missing one of the main clips (the big dog leg one) and alowed the shoes to sit on an angle.This is not a nice fix by any rate, but when you gotta get it free. I tell ya what though, I was in the shed wheeling out the oxy when it come free. Link to comment https://www.fordxr6turbo.com/forum/topic/42436-hand-brake-stuck-on/page/2/#findComment-633101 Share on other sites More sharing options...
