Just Installed Injectors And Car Wont Start
  • Replies 44
  • Mmmmm......BOOST
  • Member For: 17y 8m 17d
as said they still start no matter what injecter is in there just don't run optimum
something else has gone wrong here
  • Mmmmm......BOOST
I rekon that's BS and if he puts the stockies back in with a stock tune he will have it sorted, still his choice.
Scotty
if you read some of the other posts I'm not the only one that has had siemens put in and had the car running before the scaling was done
as the bloke said looks like a flash problem he's tunes are loading in 15 secs
anyway was goin to be tuned today so if it wasn't sorted I think it's probly been towed to workshop already
Edited by our06t
  • Member For: 17y 1m 5d
pull out the fuze for the fuel pump then crank it over to clear out the fuel, it may even start for a sec then put a little fuel in the T.B to see if it fires up and tries to run. Maby check the tps is hooked up befor you do this. At least it will help narrow down a few things.
  • Member For: 18y 9m 24d
KS as I said earlier it will start on stock tune with dekas, I have seen it before. Runs a little lumpy but that's about it. If the car has fuel coming out the exhaust means the injectors are working. Problem is elsewhere.
Hope you got it towed.
  • Member For: 17y 1m 24d
Got it towed to BPT and it should be done today. When I called they said they where still figuring out the source of the problem but there was no pressure in the fuel lines. Maybie the fuel pump died on the ass? But why can I smell fuel from the exhaust then??
DUN DUN DUNNNNNNNNNNN!!!!!!!!!!
All this will be answered tonight!(if im not to busy testing out me new 300+rwkw) :)
