Just Installed Injectors And Car Wont Start
  • Member For: 17y 1m 6d
hmmmm......Dont know what I could have done. It was quite a easy job. Didnt take to long. I didnt need to disconnect any hoses except for a the plazmaman throttle body and intake piping. All the usual lights come on on the cluster. Fuel pump turns on. Sounds like theres no fuel getting through ot its flooded?
  • Replies 44
  • Here since the start...
  • Member For: 21y 8m 2d
Flash the stock tune in and see if that makes a difference.
I wouldn't drive around on a stock tune with larger injectors but you can at least start it safely.
have you tried the stock tune
just a thought disconnect the neg battery terminal for 10 mins then try again
I just loaded up the stock tune and the same thing is happening. The injectors turn a bit. I noticed that the new one dont have a little tab on them like the factory ones to stop them from turning.
Is this a problem at all??
Have you plugged the throttle body plug back in?
Double check everything you touched while swapping them over, if all is ok, the tune may be dodgy
yep, throttle body plug is back in. Im going right over it now and double checking everything.
I can smell fuel coming from the exhaust. Which makes me think the cars flooded and theres to much fuel and not enough air. Iv also noticed that my flash box is loading up tunes in around 15 seconds. I dont think it loaded them up that quick befor. Is sounding like a tune issue? or should I start checking the throttle body?
  • Mmmmm......BOOST
  • Member For: 17y 8m
might sound dumb but you are folowing the install instructions properly
plug in tuner
select tune
turn key till dash lights up leave it for a couple of minutes
turn off
and remove flashbox
if all else fails don't stress get it towed to workshop for $150 or so and let them sort it for you
