senna_T Forged Member Lifetime Members 15,818 Member For: 18y 20d Gender: Male Location: SW Sydney Posted 08/02/08 06:07 AM Share Posted 08/02/08 06:07 AM It looks the biz mate, just be careful with your diff! Link to comment Share on other sites More sharing options...
Josh636 Member 65 Member For: 17y 4m 24d Gender: Male Location: Mount Isa Posted 08/02/08 08:57 AM Author Share Posted 08/02/08 08:57 AM Also forgot to add another $140 for bushes for front rear and centre of springs....parked it up before and took a pic, diff is sitting on the bump stop cos other side is in a ditch...looks hot....thinkin I might chop the bump stops and get 1 inch lowering blocks:Danyone find the rear wheel is closer to the front when lowered? also where the spring bolts up at the front there is a second hole up and back more?? anyone know used that hole? Link to comment Share on other sites More sharing options...
fordboy1981 Donating Members 2,075 Member For: 22y 1m 10d Gender: Male Location: Sydney, NSW Posted 08/02/08 11:23 AM Share Posted 08/02/08 11:23 AM look great mate Link to comment Share on other sites More sharing options...
Josh636 Member 65 Member For: 17y 4m 24d Gender: Male Location: Mount Isa Posted 09/02/08 12:51 AM Author Share Posted 09/02/08 12:51 AM had a look under the ute today after some more banging from the rear when gettin sideways, near the front of the spring where there is a clamp to hold the springs together it is smashing the chassis... Link to comment Share on other sites More sharing options...
forced Member 97 Member For: 19y 1m 30d Gender: Male Location: south australia Posted 10/02/08 05:10 AM Share Posted 10/02/08 05:10 AM yep mine has done the same the springs hit the chassis and have you got bad axle tramp now that you have lowered the ute for my ute got that bad I went back to standard Link to comment Share on other sites More sharing options...
Josh636 Member 65 Member For: 17y 4m 24d Gender: Male Location: Mount Isa Posted 10/02/08 05:36 AM Author Share Posted 10/02/08 05:36 AM yeah bad as, think when the rear squats down the wheel rubs on the plastic inner guard at the back, if ya punch it in first it just had a clicking/thud sound. Maybe its for a good thing though stops from doin skids, 20s only lasted about 2000ks down to the markers....looks hot just cant drive it as hard anymore... Link to comment Share on other sites More sharing options...
steetf6 Banned 163 Member For: 17y 1m 3d Gender: Male Location: wa Posted 10/02/08 05:52 AM Share Posted 10/02/08 05:52 AM be carefull with the tramp it cause damage he he Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 10m 3d Gender: Male Location: Brisbane Posted 10/02/08 05:57 AM Share Posted 10/02/08 05:57 AM Link to comment Share on other sites More sharing options...
forced Member 97 Member For: 19y 1m 30d Gender: Male Location: south australia Posted 10/02/08 07:29 AM Share Posted 10/02/08 07:29 AM yep mine hits the plastic and ive only got 18x275 standard springs are thicker than aftermarket and aslo have the thick flat spring on the bottom which helps with the tramp. got 380 at rear in an auto and when it gets into 3rd it tramps real bad so I used the king spring top leaf for it has the bush eyelet turned down to lower the ute and the rest I used the standard springs which has helped Link to comment Share on other sites More sharing options...
Josh636 Member 65 Member For: 17y 4m 24d Gender: Male Location: Mount Isa Posted 10/02/08 11:15 AM Author Share Posted 10/02/08 11:15 AM the kings leafs have more springs which I guess helps stiffen up the rear for bumps but the thin top spring doesnt stop the flex under power. using the kings and standard together how much lower did it make it? I found the rear is alot stiffer and feels good over the bumps but just squats right down under power, plus I have about 60kw more then when I had the standards..hehelooking at gettin some new shockers to combat tramp Link to comment Share on other sites More sharing options...
