O2STOCK Donating Members 607 Member For: 19y 5m 6d Location: Brisbane Posted 24/01/08 10:20 AM Share Posted 24/01/08 10:20 AM Hay guysDoes any one know how to check the oil level on a AUII 4sp Auto ? Gearbox Chears James Link to comment Share on other sites More sharing options...
XR6menace BANNED Banned 1,462 Member For: 17y 9m 23d Gender: Not Telling Location: banned Posted 29/01/08 08:54 AM Share Posted 29/01/08 08:54 AM I think you already know ????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????Remove the fill plug and measure with your pinky ! Link to comment Share on other sites More sharing options...
private9 Member 49 Member For: 17y 1m 23d Gender: Male Posted 18/03/08 09:58 AM Share Posted 18/03/08 09:58 AM I think you already know ????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????Remove the fill plug and measure with your pinky !Exactly! Gotta wish there was an easier way though! Link to comment Share on other sites More sharing options...
slo_au2 Member 22 Member For: 16y 10m Gender: Male Location: Langwarrin, Victoria Posted 20/04/08 01:51 AM Share Posted 20/04/08 01:51 AM If you can Manage , go to AutoBarn and Purchase a Tom Thumb Hand Pump .. you can Fill it with 95LE Fluid because its not really Thick.As for checking it .. Bend a Coat Hanger on a 90º Angel with an Inch on the end and Insert into filler hole .. remove and check levels .. anything less than 1cm below the filler hole will need Roughly 1.2 Litres of 95LE ..Hope this Helps ..Daniel Link to comment Share on other sites More sharing options...
Guest Guests Posted 20/04/08 04:29 AM Share Posted 20/04/08 04:29 AM top it up till it comes back out or.........As for checking it .. Bend a Coat Hanger on a 90º Angel with an Inch on the end and Insert into filler hole .. remove and check levels .. anything less than 1cm below the filler hole will need Roughly 1.2 Litres of 95LE ..sounds a bit better. Link to comment Share on other sites More sharing options...
slo_au2 Member 22 Member For: 16y 10m Gender: Male Location: Langwarrin, Victoria Posted 20/04/08 05:59 AM Share Posted 20/04/08 05:59 AM Yeah , have done it a few times .. Just be carefull if your not real knowledgeable with Nuts and bolts , as the Trans Filler Plugs are Really Crap Metal , and Thread easy ..CheersDaniel Link to comment Share on other sites More sharing options...
CJ_AK cj_ak Donating Members 5,077 Member For: 17y 7m 20d Gender: Male Location: Ropes Crossing Posted 06/06/08 10:56 AM Share Posted 06/06/08 10:56 AM Can anyone describe a 'Tom Thumb Hand Pump'??is it possible to refill the gearbox oil any other way?? Link to comment Share on other sites More sharing options...
slo_au2 Member 22 Member For: 16y 10m Gender: Male Location: Langwarrin, Victoria Posted 08/06/08 08:39 AM Share Posted 08/06/08 08:39 AM Can anyone describe a 'Tom Thumb Hand Pump'??is it possible to refill the gearbox oil any other way??Tom Thumb is the Brand , Its a Plastic bottle with a Red handle , and a Hose with a metal End , you Fill with your Desired Flavour of Oil and Start P{umping .. Link to comment Share on other sites More sharing options...
proddy68 Member 29 Member For: 16y 9m 25d Posted 11/06/08 06:39 AM Share Posted 11/06/08 06:39 AM Can anyone describe a 'Tom Thumb Hand Pump'??is it possible to refill the gearbox oil any other way??Its a sealed unit so unfortunately besides from pumping it in as described there is no easy way. Link to comment Share on other sites More sharing options...
