krooked Member 34 Member For: 17y 2m 8d Gender: Male Location: Heathwood Bris Posted 21/01/08 09:50 PM Share Posted 21/01/08 09:50 PM What is the biggest width rim you can fit under the back of a ute?? I have 20 x 8.5 atm and they are just useless in the wet, I know that being 20s doesn`t really help the cause at all but will 10s fit under the rear??? Link to comment Share on other sites More sharing options...
Gavin.K Member 288 Member For: 19y 7m 18d Gender: Male Location: sydney Posted 21/01/08 10:18 PM Share Posted 21/01/08 10:18 PM I have 275r19/30 on mine no problem. Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 4m 22d Gender: Male Location: Mildura Posted 22/01/08 02:20 AM Share Posted 22/01/08 02:20 AM 20x10's fit but you can only run a 275.you can run 285's if u lip the guards but no wider as they are about 3mm off the leaf spring!19x9.5's seem to be a really safe size and look horn Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 1m 6d Gender: Male Location: Sydney Posted 22/01/08 02:50 AM Share Posted 22/01/08 02:50 AM 20x10's fit but you can only run a 275.you can run 285's if u lip the guards but no wider as they are about 3mm off the leaf spring!19x9.5's seem to be a really safe size and look hornDitto for the sedan.... but without the leaf spring!Brian Link to comment Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 18y 9m 11d Posted 22/01/08 03:56 AM Share Posted 22/01/08 03:56 AM What is the biggest width rim you can fit under the back of a ute?? I have 20 x 8.5 atm and they are just useless in the wet, I know that being 20s doesn`t really help the cause at all but will 10s fit under the rear???Purchase decent rubber not cheap sh*t ching chong tyres!Pirelli Corsa's or Bridgestone RE-01R's semi slicks will give a massive incresase in traction Link to comment Share on other sites More sharing options...
hackisack Member 33 Member For: 17y 6m 4d Posted 26/01/08 04:42 AM Share Posted 26/01/08 04:42 AM I'm running 20x8.5 with 275's on the back of mine. fit no probs but you can't expect too much traction with a powerful ute in the wet! Link to comment Share on other sites More sharing options...
TH0MM0 Member 244 Member For: 17y 2m 30d Gender: Male Location: Perth, Forrestfield Posted 28/01/08 11:06 AM Share Posted 28/01/08 11:06 AM ive got 19x9.5 with 275s Link to comment Share on other sites More sharing options...
igy17 Member 24 Member For: 17y 5m Gender: Male Location: freo Posted 29/01/08 01:18 PM Share Posted 29/01/08 01:18 PM ive got 19x9.5 with 275ssame.no problems with guard rubbing.utes 40 mm lower at back Link to comment Share on other sites More sharing options...
TH0MM0 Member 244 Member For: 17y 2m 30d Gender: Male Location: Perth, Forrestfield Posted 30/01/08 02:34 AM Share Posted 30/01/08 02:34 AM got any pics of that ? Link to comment Share on other sites More sharing options...
igy17 Member 24 Member For: 17y 5m Gender: Male Location: freo Posted 30/01/08 01:06 PM Share Posted 30/01/08 01:06 PM got any pics of that ?hows that mate! Link to comment Share on other sites More sharing options...
