4"dump And 3.5 Metal Cat's Group Buy
Tree Monkey
  • Member For: 17y 2m
[url="http://www.bestmufflers.com/Information/Custom%20Systems/custom_exhaust_system_ford_xr6_6cyl_Dyno_Results.htm"]http://www.bestmufflers.com/Information/Cu...yno_Results.htm[/url]
it works on that car!!!!! maby even enough back pressure to stop the boost from going up. as per other post the dump helps you make power at lower boost and stress on the motor.
  • Replies 57
  • Member For: 17y 5m 11d
[quote name='Tree Monkey' post='622511' date='Jan 19 2008, 07:16 AM']i am prity sure that it is only the inlet and outlet size that is 3.5", the body is aprox 4-5" but i will find out for you all. Now how many other options do you want or should i change the hedding to, Tell me all the diiferant things you all want? I am only going as far as seeing what a group buy for a dump & cat, i will find out about the y pipe and cat only as an option as well. I am not going to stuff them around with 101 questions unless i buy a set first.[/quote]
How about the whole system. 4" Dump, Cat and 3.5" single system or 2.5" twin system?
Otherwise I am keen for the dump and will get the cat and back system fabbed up locally.
Jimmy
a full system 4'or 3.5' dump ,cat and mild twin 2.5" system is aprox $990 all bolt up. Thats the system i am going for of maby a quad for around $200 more
this is the one i am going to use, i am going to open the inlet side of the cat to 4" Edited by Dagabond
  • TEAM BA
  • Member For: 20y 2m 1d
[quote name='Tree Monkey' post='622662' date='Jan 19 2008, 06:05 PM']it works on that car!!!!! maby even enough back pressure to stop the boost from going up. as per other post the dump helps you make power at lower boost and stress on the motor.[/quote]
I dont disagree that it will work.. and perform well.. I just question the logic in using a smaller cat (especially given you have to modify said cat) when there is a bigger one available that better suits the dump pipe
  • Member For: 17y 4m 6d
Tree monkey,
Whats the status on the group buy for the dump and cat?
Seems like this whole thread has been screwed up by people after something different. Original idea was for dump and cat, so maybe we could stick to that and get something happening? For others that want a full system, research and organise a full system group buy. *end of rant*
i am going to find out a price on ONLY the following:-
opt 1= 4" dump and 3.5"cat $630
opt 2= 4" dump and 3.5"cat and y pipe
opt 3= 3.5"dump and cat $630
opt 4= 3.5"dump and cat and y pipe
opt 5= either dump and cat combo and full mild twin2.5" system $
if you just want a cat go to the pound, lol, or do a deal with someone for spliting a set.
THIS IS A GROUP BUY OF 5 UNITS OF OPT 1 OR 3 MIXED, 2 OR 4 MIXED, OR 5 SETS OF 5.
i want to place the order by thur 31 jan and require a deposit paid on the items you want. I will try to get the supplier to take payment directly, or welcome you to come to my place to sort out the rest.
Guest
This topic is now closed to further replies.
