ROLMDL role model Member 1,111 Member For: 18y 9m 18d Gender: Male Location: Melbourne,S.E Posted 18/01/08 06:04 AM Share Posted 18/01/08 06:04 AM oops well reset the ECU with what ever tune was in it. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 6m 5d Gender: Male Posted 18/01/08 06:12 AM Share Posted 18/01/08 06:12 AM happened twice to mine, but in the end I managed to load the factory tune back into it. once it started with that in back to the 10psi and away I went again.odd for you to be able to load all the tunes then it stop working. have you tried the other tunes in the box? (since the failure I mean) Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m 2d Gender: Male Location: Victoria Posted 18/01/08 06:46 AM Share Posted 18/01/08 06:46 AM Did you load the stock tune to the box first? Link to comment Share on other sites More sharing options...
4 work & play Member 43 Member For: 18y 5m 18d Gender: Male Location: Vicco Posted 18/01/08 10:31 AM Author Share Posted 18/01/08 10:31 AM Hi guys,I followed the instructions which were given with the flasher.The first tune took about 5 minutes, once the lights stopped flahing I left it be for probably 20 - 30 seconds and then turned the ignition off and pulled the connection. the car started and ran fine. I guess the stock tune went into the flasher, but if the box is faulty, then perhaps something has gone wrong with storing the info??????????????????? All I can say is that I read the instructions about 5 times before I did it and had the instructions in front of me when I flashed the car. It worked twice, then sh%t hit the fan.I spoke to Jeff from C & V today and he haden't heard of such an incident before, where no tune could be loaded and the car couldnt be started or driven. I will be calling him again soon when I am in the car just to go thru everything and he seems very helpful, so hopefully we can work it out.I appreciate all the suggestions and info guys, I will keep you posted on what the result ends up being.I just hope that it ends up being an easy solution.Just quickly, doesent the word - CODE on the stereo just mean that a pass word needs to be input for the stereo to work again????? Surely not that the whole computer needs reprogramming like what blueprintxr6t is suggesting?Can you shed more light blueprintxr6t, did your prob occur from retuning, or what was the cause?CheersSean Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 3d Gender: Male Location: Brisbane Posted 18/01/08 10:35 AM Share Posted 18/01/08 10:35 AM The "CODE" will disappear a few seconds after you start the car...it's coded with the PCM, not an actual code you enter as such. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m 2d Gender: Male Location: Victoria Posted 18/01/08 10:37 AM Share Posted 18/01/08 10:37 AM The ICC will take care of that by itself once the PCM is functioning properly. You don't have to manually enter a code like in earlier Falcon's. Link to comment Share on other sites More sharing options...
4 work & play Member 43 Member For: 18y 5m 18d Gender: Male Location: Vicco Posted 18/01/08 10:49 AM Author Share Posted 18/01/08 10:49 AM (edited) Ahh, ok. Hmmmmmmmm, perhaps a new flash box may resolve my problem, however I do have reservations that its going to be as simple as that! Jeff has indicated that the box may be faulty, I dont care what tune I get into the car as long as I can drive it, I will go and get a custom tune! Edited 18/01/08 10:50 AM by 4 work & play Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m 2d Gender: Male Location: Victoria Posted 18/01/08 10:51 AM Share Posted 18/01/08 10:51 AM The best thing would be to take it to your dealer and get them to reflash a stock calibration into it. Link to comment Share on other sites More sharing options...
Blueprintxr6T Member 93 Member For: 19y 8m 7d Gender: Male Location: Toowoomba Posted 19/01/08 01:17 AM Share Posted 19/01/08 01:17 AM Mine happened under the same circumstances as yours.. my flash box wouldnt allow any tunes to be falshed to the car.. I had the car towed to ford under the ford assist idea.. ford informed me that the whole computer including the pcm had lost its memory.. they spent hours getting the car right for me again.. getting it to run wasnt a problem but from what they said they need to reteach the speedo to work and the gearbox to change.. thsi took them 2 days (thankfully they did it as waranty).. I sent the box back to capa they did tests and said the box was ok and sent it back to me.. everything worked well for bout 6 months then the same thing happened again.. another trip to ford on the tilt tray and they reprogrammed the car for me this time costing I think $50.. Capa got my box snet back to them through Dyno Wog and they are still stuffing us around saying it was sent back to the states for further testing... that was over 12 months ago.. I've got a new car since then and am going to use the sniper tuning software thsi time.. hope this helps you out some more.. if not pm me and I'll give you my number Link to comment Share on other sites More sharing options...
4 work & play Member 43 Member For: 18y 5m 18d Gender: Male Location: Vicco Posted 19/01/08 08:30 AM Author Share Posted 19/01/08 08:30 AM Well Good news! I managed to get the valet tune to load in first thing this morning. I drove around the block to be sure that it was at least driveable (under 3000rpm of course)I then called Jeff at C & V and we stepped through loading the factory tune back in, which it did fine. I'm not sure why it has started working now. When I was trying to load a program in before it would just be stuck on the two LEDS 00 00 pattern (22 Code), but now it seems to be going through the whole senario and downloading the tunes. However I still have a problem downloading the 8 PSI tune, which wont go past the 22 code, so I'll send the box back to C & V for them to look at it.So good news, thank you all for your help it is much appreciated.And now that I have it running properly on the 10 PSI tune....................how good is it! The mod bug has already got me (which I knew would) and I want more So looks like I'll be collecting a few goodies in the next couple of months before getting a custom tune CheersSean Link to comment Share on other sites More sharing options...
