4 work & play Member 43 Member For: 18y 6m 5d Gender: Male Location: Vicco Posted 17/01/08 09:36 AM Share Posted 17/01/08 09:36 AM (edited) hi guys,We'll I got my tuner today, plugged it into the car loaded the 10 psi tune, turned car on all sweet........went for a drive down the road..........sweet...........thought hmmmmm, wonder what the 8psi tune is like, so pulled over went bthrough the load sequence again (although I did notice that the factory LED wasnt lighting up as an option), so anyway car started up again sweet went for a drive again, then thought nah the 10psi is the GO. So went through the sequence again only this time at the end it started flashing error code 22 - Invalid calibration. Ok, tried again.............same thing, and of course now the car wont start at all. Now my car is stranded on the side of the road. What is wrong.......and how can I fix it??????????????? Edited 17/01/08 09:38 AM by 4 work & play Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 9m 22d Gender: Male Location: nsw Posted 17/01/08 09:40 AM Share Posted 17/01/08 09:40 AM try loading the f slot. are you doing it right.reds off plug in the box press select to select the desired program press program and wait for flashing lights turn on reds and wait untill program loads. turn off reds and disconnect box.where did u get your box from? Link to comment Share on other sites More sharing options...
4 work & play Member 43 Member For: 18y 6m 5d Gender: Male Location: Vicco Posted 17/01/08 09:43 AM Author Share Posted 17/01/08 09:43 AM Thanks for the quick reply.By reds I'm assuming you mean the red lights on the dash, if so, yeah that's the order I did it in. It worked twice, car was running sweet, just when I went to tune the third time it packed up??????? Link to comment Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 18y 10m 5d Gender: Male Location: Melbourne,S.E Posted 17/01/08 09:47 AM Share Posted 17/01/08 09:47 AM (edited) turn car offplug the box inselect map F P1 P2 P3hold down program till lights start flashingturn the key so that the lights on the dash come onwait till all the lights have fisnhed flashing on the boxs and wait for the solidorange light to come on the boxs.turn the key offpull the plug out start the car.=) Edited 17/01/08 09:49 AM by UNV3ME Link to comment Share on other sites More sharing options...
4 work & play Member 43 Member For: 18y 6m 5d Gender: Male Location: Vicco Posted 17/01/08 09:55 AM Author Share Posted 17/01/08 09:55 AM Yeah that's exactly how it was done! that's why I cant work out why it wont load up now. I tried the sequence probably 5 or 6 times again but it kept coming up with the error code.Its not complicated I know, and I feel like a goose coming on here with this problem, but it has happened and now I need to to know why this is happening and how it can be remedied.So frustrating. Link to comment Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 18y 10m 5d Gender: Male Location: Melbourne,S.E Posted 17/01/08 10:01 AM Share Posted 17/01/08 10:01 AM so the car not turning on at all?mabye just try dissconnect the battery "negative first"wait 5-10mins.reconnect it up and see if the car starts if so then try re flash the car again. Link to comment Share on other sites More sharing options...
4 work & play Member 43 Member For: 18y 6m 5d Gender: Male Location: Vicco Posted 17/01/08 10:21 AM Author Share Posted 17/01/08 10:21 AM Car ignition will turn on, but the car won't turn over???????????Justwent back down the road and tried again, but its a no go, will try the battery trick, otherwise it will be towed home and will worry about it later. Thanks for your help.CheersSean Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 7m 19d Gender: Male Location: @ my laptop Posted 17/01/08 10:37 AM Share Posted 17/01/08 10:37 AM is the car in park? assuming it's an auto Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 6m 8d Gender: Male Location: The 8th Dimension Posted 17/01/08 10:42 AM Share Posted 17/01/08 10:42 AM It could not be that, please don't be that Link to comment Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 18y 10m 5d Gender: Male Location: Melbourne,S.E Posted 17/01/08 10:47 AM Share Posted 17/01/08 10:47 AM if it is it gonig down in the record book ahhaha Link to comment Share on other sites More sharing options...
