Transmission Coolers
MiKa
  • Member For: 18y 6m 11d
Ok im gonna up the power fairly soon and thought I'd invest in a tranny cooler for the 4sp, what I wanna know is,
What brand to get?
I've heard B&M are the best brand but they dont come with lines, and are expensive. Seen a PWR one on Ebay, it measures 280x200x19 for $130...
Is that big enough?
What size do you have?
Where did you get it from?
How much was it?
Where is the best place to mount it? I will have a wog cooler.
BTW tried the search but it only came up with tranny coolers for a 6sp auto
Cheers Mike
  • Replies 49
Posted Images
  • Member For: 18y 9m 12d
Basically, use the biggest that will fit in the chosen area.
I know of Turbo falcons (not just BA/BF, but same deal) that run twin 300mm x 300mm, one on each side with a thermofan on each.
There's no set "must have size" but you will need a decent sized cooler... and not the slim type that "Joe's garage" puts on for a tow car.
Cheers
Chris
  • FORD FORD FORD
  • Member For: 21y 11m 15d
If u r genuinely concerned u will fit a temp guage that will tell u if whichever cooler u end up fitting is adequate or not, nobody can tell u what is enuf or not, cause it depends on how when and where u drive, a guage will however keep u informed at all times, DO NOT MOUNT A CAPIILARY GUAGE INSIDE THE CABIN.
  • Into the laaaake
  • Member For: 17y 8m 18d
Here mate, ive made a few posts that may help.
Trans cooler: http://www.fordxr6turbo.com/forum/index.ph...hl=trans+cooler
I/C install with Trans Cooler: http://www.fordxr6turbo.com/forum/index.ph...l=monza+install
I dont plan on putting another guage in the cabin, and I am only genuinely concerned enuf to put a tranny cooler on.. Im just after some ideas on what other people have fitted so as I have a rough idea on what to get and a rough size of what im able to fit..
I just saw that I spelt transmission wrong so the search had alot more answers this time round.. I like hiddeous' setup with the cooler mounted infront of the drivers wheel.. Now just need to find a cooler that will fit that position..
I think the PWR cooler I linked up in a previous post would fit.. But I think he fabbed up his own mounts so that's gonna be a pain...
I think the majority of people are running the tranny cooler on its own without the radiator one, so im gonna head down that path to..
Anymore options on coolers guys??
  • Into the laaaake
Edit: link now goods.
Edited by hanra
