What Injectors Are Best.?
  • Member For: 17y 3m 27d
Just been reading around and have noticed some people run 968 bosch injectors and other's run siemens deka's, what I want to know is, does any of them have an advantage over the other or there basically as good as each other or 1 particular brand is better but more expensive etc etc.?
Looking at purchasing some injectors and am up in the air as to what to buy.
Cheers
  • Mad Scientist
  • Member For: 20y 3m 3d
the 968's are 42lbs and the Siemens are 60lbs, not sure when the 968's run out of puff, I think the Siemens are good for 400-450rwkw, plus the Siemens are cheaper to :spoton:
Does anybody know how many CC's both the Siemens and the 968's are by any chance...?
Any help will be appreciated...
Edited by JETFPV
  • Member For: 18y 11m 11d
Depends, the dekas are rated at 60lbs at 3bar fuel pressure, and I will assume 968s at 42lbs at 3bar. Our fuel system runs 4bar.
@ 3 bar pressure
lbs/hour = cc per minute / 10.2
60 x 10.2 = 612cc (dekas)
42 x 10.2 = 428.4cc (968s)
@ 4 bar pressure
4 bar flow rate (cc) = ((square root) 4bar (psi) /3bar (psi)) x 3 bar flow rare (cc)
((square root) 58/43.5) x 612
((square root) 1.333) x 612 =
1.155 x 612 = 707cc (dekas)
1.155 x 428.4 = 495cc (968s)
