Ford Service
coupeboy351
  • You are a dead set goose
  • Member For: 19y 2m 12d
Can you please describe this handbrake swoosh noise?
I've been having issues with the back disks on the BA, and I think it's the handbrake that causes the back wheels to squeek under light braking. They told me that the rear brake lines were recalled and need to be replaced at the next service, however I don't think that would solve the grinding and squeeking.
This could be the same issue?
Then again, I heard that the handbrake is on the rear axle and not connected to the rear disks on Falcons?
Edited by theblueyjr
  • Replies 21
  • Member For: 19y 4m 25d
Exact same thing happened to me man your not alone.
Fact is they dont care they always back there service men to the very end.
Just lay a dirty fart in the office when your grabbin your keys its all they deserve LOL
AAAAHAHAHAHA
:buttrock:
I might just hang a massive AGB borry near the door when I come in, wipe my sticky sh*t encrusted ass with my hand and overenthusiastically run around shaking everyone's hand like I'm mentally challenged next time I go in a Ford dealership. :Doh:
  • Member For: 17y 7m 18d
ROFL...
yeah the handbrake design is a p.o.s...Basically like a drum brake setup that presses a large semi circular shoe against the inside of the Rotor hub.
The cyclic swoosh can be heard at low speeds, (20 - 40 kmh) and especially if you drive with the window down and there are nearby walls, cars etc for the sound to reflect back at you. I heard it every morning as my wife drives off to work, drove me nuts.
basically all BA's do it unless its been addressed in the TSB.
Get it done at the same time they replace the rear hoses on recall, just insist that they do the full TSB and not just install the new centering spring, it must be adjusted on the cable adjuster on the inside of the dust sheild.
they will cheat and try to just adjust the main cable tension, not the correct way to set it up.
  • Member For: 17y 1m 13d
Ford Service... what can you say really. Went to QFord with a warranty problem..... 6 visits later still not fixed. So now I seek help elsewhere.
Cheers Adam
  • Member For: 18y 5m 7d
Never been to a Ford dealer who hasn't f*cked up a job, and over the years I've tried 8 of em. For me they have a 100% record of f*cking things up (mind you, other manufactuer's track records aren't much better). On the other side of the coin, in nearly 20 years of driving, I've only ever had 2 f*ck-ups from indipendent workshops.
The latest is it went in to fix the steering clunk mid last year. Came out with a fried CD player because they decided to try and reset my heater unit. Took two months and three visits to replace the CD player, then took another 2 months to get my CDs back. All of the CDs are scratched to buggery, cracked and gouged. I am still trying to get an answer from them about replacing the CDs.
  • Member For: 17y 1m 1d
Way back when, I had an XF, an EB and an EF all serviced by dealers from new. Never had a dealer problem. The EF harmonic balancer became unbonded at around 60,000km and the pulley slipped back and wiped out the crank position sensor. The engine died and I got stuck in the bush for days. I got towed to a Mazda dealer (the only workshop in the nearest town) and the new harmonic balancer and sensor were ordered and fitted.
When I got home, I went to my Ford dealer and discussed the problem I had. They told me it was not an isolated incident and PAID for ALL my expenses, even though the car was out of warranty by 6 months.
Good guys!
Hopefully they are still OK 10 years later.
I did have a shocker with a Mitsubishi dealer though. 90,000km Magna service and the timing belt was changed. A couple of days later I was coasting down a big hill and all the lights came on. The engine wouldn't restart and sounded a bit weird when cranking. Got towed to my dealer who had a quick look and told me I was in big trouble - the belt had jumped. I told them they were in big trouble since they just fitted the new belt. It turned out that some sap in the workshop dropped a M6 nut into the hole when changing the air filter. Big vacuum down the hill and the nut went into #1 cylinder. It "hydraulicked" the piston, bent the rod, jumped the belt and bent all 24 valves. The service manager idiotically showed me the pounded nut and the dents on the top of the piston and tried to tell me that the nut fell off from somewhere inside the engine and that I was going to have to pay for it all.
I got both heads rebuilt for free, new piston, rings etc. Unbelievable.
Edited by John K
  • Member For: 17y 5m 15d
they lost me as a customer when they did this to me and blamed me and then asked me to pay $275 to fix.
I ordered a cable from bayford on ebay $30 and it came 2 days later and I fixed it myself(new design handle) it took 15 min for me and I've never done one before.
Why wouldn't my dealer have said you pay for the cable and we will fit it free and keep their customers happy and coming back, BAD FORM FORD
