tab Sucker Moderating Team 32,303 Member For: 21y 1m 26d Gender: Male Location: Brisbane Posted 15/01/08 09:56 AM Share Posted 15/01/08 09:56 AM All but two of the posts assumed that anyway I think Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-620884 Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 18y 4m 6d Gender: Male Location: SYDNEY Posted 15/01/08 10:00 AM Author Share Posted 15/01/08 10:00 AM (edited) Thanks tab your a champ can you edit my first post CHeersPete Edited 15/01/08 10:04 AM by LUMO Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-620889 Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 11m 28d Gender: Male Posted 16/01/08 12:50 AM Share Posted 16/01/08 12:50 AM I think that bugster70 had the same problem when he put his leather in, but he hasn't been on the forum for yonks! you will be able to tell if your new seats have airbags as there will be a plastic cover on the side of the seat that says srs or airbag. Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-621099 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 7m 12d Gender: Male Location: Perth, NOR Posted 16/01/08 02:01 AM Share Posted 16/01/08 02:01 AM I think they also have a little tag sticking out the side with AIRBAG or something written on it. Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-621113 Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 18y 4m 6d Gender: Male Location: SYDNEY Posted 16/01/08 06:52 AM Author Share Posted 16/01/08 06:52 AM Cant see anything guys that says air bag on it Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-621206 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 2m 27d Gender: Male Location: New Zealand Posted 16/01/08 07:09 AM Share Posted 16/01/08 07:09 AM LUMO said: Cant see anything guys that says air bag on it My tags are beside your shoulder on the outer side of the car - made out of leather the same colour as the seat - looks a bit like a tag inside your shirt Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-621213 Share on other sites More sharing options...
grepin Member 109 Member For: 18y 5m 9d Posted 20/01/08 01:55 AM Share Posted 20/01/08 01:55 AM cobrav8 said: My tags are beside your shoulder on the outer side of the car - made out of leather the same colour as the seat - looks a bit like a tag inside your shirtI was told by an upholsterer that if you turn your ignition on with the seats disconnected your airbag light will stay on. Regardless if its airbag or not I assume as he said it about mine being non airbag.He said ford will need to re-set it. I dont know how true this is. Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-622891 Share on other sites More sharing options...
Rickc14 New Member 2 Member For: 6y 3m 28d Posted 23/02/19 01:23 AM Share Posted 23/02/19 01:23 AM I’m not sure if this is the same problem you are having. But I swapped my seats from ones with airbags to ones without. When I did this it threw an airbag fault as it was missing two airbags. So to combat this fault you need to go buy a 2.2 ohm 1watt resistor from jaycar and either do a bodge and jam it into the two inner pins of the airbag plug or solder them into the wires that lead to those two inner pins. This tricks the computer into thinking it has airbags in the seats and stops the code. This worked on my 2011 fg falcon Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-1676079 Share on other sites More sharing options...
Snowy069 New Member 3 Member For: 6y 2m 12d Posted 08/04/19 05:00 PM Share Posted 08/04/19 05:00 PM Hey guys, got the same problem in my BF2.5. Swapped the seats from cloth NON airbag type to leather WITH airbags. Ever since had code 23 flash up. Tonight I took the resistor plugs from my other BF2 and disconnected the seats from the loom and plugged in the dummy yellow resistor plugs and the light went out. However I'm sure this has now disabled the side seat airbags. What's the proper way to fix this so the seat airbags deploy in case of an accident? I do remember switching on th ignition foolishly before plugging in the connectors and wondered if just an SRS reset would fix the problem? Is there a way to reset the system in a BF without an SRS reset tool like the EF by shorting out say pin 4 in the diagnostic plug? Any help would be greatly appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-1681015 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 1m 29d Gender: Male Location: Canberra ACT Posted 08/04/19 08:27 PM Share Posted 08/04/19 08:27 PM I'm not quite sure it is that simple mate - if your car didn't have side airbags from factory, it won't have the correct control module, side impact sensors or maybe even wiring loom to support the additional airbags. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/41579-airbag-light-comes-on-after-i-upgraded-to-leather-seats/page/2/#findComment-1681017 Share on other sites More sharing options...
