moocho XR6T-Ute Member 2 Member For: 17y 3m 24d Gender: Male Location: Canning Vale Posted 12/01/08 01:02 AM Share Posted 12/01/08 01:02 AM Hi all im new to this forum stuff. Anyways I just got a new xr6t ute manual, I was hoping to get some help here on when I should flash tune my car it only has 1055k's so far, should I wait for atleast 5000k's or...? and if anyone could recommend a nice sounding exhaust setup be mush appreciated. Cheers.. Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/ Share on other sites More sharing options...
Blueprintxr6T Member 93 Member For: 20y 15d Gender: Male Location: Toowoomba Posted 12/01/08 01:38 AM Share Posted 12/01/08 01:38 AM Hi and everybody has differnt ideas on when it is right and wrong to flash your car.. I know of a couple of cars on here that have been flashed with under 100km's on the clock and they are still going strong Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619637 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 5m 6d Gender: Male Location: Melbourne Posted 12/01/08 01:43 AM Share Posted 12/01/08 01:43 AM I'm also interested to know, those who do suggest to 'run in' the engine, what is the best way to do this, and does it even matter?I was under the impression that it goes it's strongest when it's first built, and then through age and natural wear and tear of the engine and the drivetrain, the thing would slowly lose power.Is it worth gritting your teeth to lockjaw and scrating together all of your self control to NOT put your foot to the floor before you have some decent k's on the clock? Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619639 Share on other sites More sharing options...
igsta Member 371 Member For: 21y 6m 27d Gender: Male Location: Sydney Posted 12/01/08 07:41 AM Share Posted 12/01/08 07:41 AM I would wait at least 3000ks so the piston rings bed in. You dont want a car that chews through oil. My car seemed to perform the best between 20 000ks and 60 000ks. I have about 90 000ks now though still going strong. Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619736 Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 11m 9d Location: Mildura Posted 12/01/08 07:53 AM Share Posted 12/01/08 07:53 AM (edited) The best way to run it in is to drive it like you stole it. nobody drives them like a nana and you certainly wont if you plan on using a flash tuner. give it 3000 km before edit my OP only Edited 12/01/08 07:57 AM by macka'sxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619740 Share on other sites More sharing options...
moocho XR6T-Ute Member 2 Member For: 17y 3m 24d Gender: Male Location: Canning Vale Posted 12/01/08 11:40 AM Author Share Posted 12/01/08 11:40 AM Thanks for the info, I think I will jus wait and do it after its 5000km's service.Does the flash tune void your warranty?? Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619785 Share on other sites More sharing options...
F6Rdodg'nroos Member 164 Member For: 17y 4m 4d Location: NSW-The Taxed State Posted 12/01/08 01:02 PM Share Posted 12/01/08 01:02 PM theblueyjr said: I'm also interested to know, those who do suggest to 'run in' the engine, what is the best way to do this, and does it even matter?I was under the impression that it goes it's strongest when it's first built, and then through age and natural wear and tear of the engine and the drivetrain, the thing would slowly lose power.Is it worth gritting your teeth to lockjaw and scrating together all of your self control to NOT put your foot to the floor before you have some decent k's on the clock?Quite the opposite - It's performance will be better with time and Kms provided its run in well.On both points -Run in:I've had 3 BF Falcons, one XR6, then XR6T now F6PhoonR, and run them all in hard, and have done 90-100,000kms in each of the first 2, and up to 3800km in the F6.1. First 500km, drive it reasonably hard but avoid going over 4500rpm, and vary the engine speed by shifting down through gears, then accelerating, dont use the brakes to slow down, say at 100km shift to 3rd, then 2nd, then take off again. Also do standing starts and positively accelerate through the gears from 0-100.2. 500-1500km, drive it harder and dont hold back, increase loads at higher revs up to 5000rpm, and do the same shift down and then accelerate up through the gears -key is vary the engine speed. DO NOT coast on freeways at low revs or drive in high gears under load. 3. Change oil at 1500km - Then Drive it like you stole it for next 1500kms3. Change oil at 3000km drive it like you stole it and still a good idea to keep varying the engine speed- shift down, load it/decellerate lthen accelerate etc.My last two had far more power after 20-50,000 then even more power at 90000+kms than new - and just kept getting better, all with this run in procedure. Its this loading and varied engine speed that beds in the rings, bearings and also provides a map for future power development. Also the FPV guys said this was good.Tuning: It would make sense then, as the engine itself starts to increase power and performance as it beds in (and run in continues after 5-10000kms up to 20,000kms) IMHO 5k would be a minimum to start tuning it - ensure the engines well bedded in and as the engine itself gets better, the tune then will be even better again.CheersPaul Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619804 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 5m 6d Gender: Male Location: Melbourne Posted 13/01/08 03:29 AM Share Posted 13/01/08 03:29 AM Sounds like a plan.Thank you for the experienced info! I drive a 100k round trip to & from work each day, so this will be easy to do and I'll clock up 5000k's in 2 months.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619920 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 10m 15d Gender: Male Posted 13/01/08 04:14 AM Share Posted 13/01/08 04:14 AM if you have any more than 15km on the clock.. you have wasted your time by not driving an edited car! Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619928 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 9m 29d Gender: Male Location: The 8th Dimension Posted 13/01/08 04:40 AM Share Posted 13/01/08 04:40 AM I would say once you have givin the run in oil the flick and you are on to a good semi or full synth oil, its time to edit. Link to comment https://www.fordxr6turbo.com/forum/topic/41562-capa-flash-tuner/#findComment-619930 Share on other sites More sharing options...
