F6 Using Oil And Thinking About Mods
Sean F6 365
  • Member For: 18y 10m 18d
You idiot maybe that's why you are using oil. Not the smartest thing to do in a brand new car you should have run the engine in first.....you can always nail him later and I wouldn't be putting 1 mod on your car until this issue is sorted as you need new rings by the sound of it and this time run the engine in.
We never used a drop between oil changes and 99% of us phoon owners ran the engine in first.
Far out ... you've done absolutely nothing wrong bloke!
Demand an oil consumption & compression test be done to resolve the issue prior to any mods.
If the Dealer is unhelpful call 1300FORD and inform them of the issue ... you must get this issue resolved BEFORE you do any mods otherwise you void you warantee!
Good luck
  • Member For: 18y 14d
What warranty is voided if Simon does a Capa tune on the Phoon?
Depends on your Ford dealer mate be up front with them and tell them what you want to do and see what they say. Most ford dealers will tell you the powertrain warranty will be void if you mod the car but you can only ask.
Good luck
This may sound a bit harsh to the bloke but how many new car owners would drive out of the car yard and give it a fistful at the first set of light!! I hope he gets it repaired asap at no cost to himself but run the engine in first then rip into it.
  • TEAM BA
  • Member For: 20y 3m 1d
I'll put my hand up for that, I ran my car in like I stole it... 60k and 330rwkw and it does not use a drop of oil, ask any dealer what you should do to run in your car and they will say "just drive it like you normally would" they dont say baby it for 1000km and then give it some
  • Member For: 21y 4m 7d
My T didnt use a litre for top-ups in 105k kms and my phoon hasnt needed a top up in its last 8K kms - these engines dont use oil. The only difference between the T and the Phoon in this regard would be the semi-synthetic vs synthetic oil
  • Member For: 17y 2m 6d
Sounds like an batch issue with rings, and not beacuse you smoked the wheels in the first few days.
Rings dont just wear out that quickly, unless theres no oil in it at all.
Run in dictates that you drive in with "purpose", maybe not smokin it up, but certainly in the 3-5000rpm range. This should not affect it drinking oil like this.
Driving like miss daisy will affect the run in worse, but even then shouldn't result in them being shot.
I think you need to have a full check on compression, with and without oil in the cylinder, that will see how well it seals.
take it back and get it fully investigated - god bad or ugly runin in doesn't matter a pinch - either way - it's a Warranty issue.
  • Member For: 19y 8m 1d
Mate this exact thing happened to me so I'll give you a quick run down of my situation and I hope it can help you in some way.
I picked up my new XR6T BA MKII 6sp manual and did the run in according to the FPV procedure. I checked the oil after 1000 km's and guess what...there was none. There was also no leaks so and the oil didn't appear to be burnt but it went somewhere?!!
I drove it to ford with what appeared no oil and when I got there and they filled it up... it had 3 lt left. Ford did a oil consumption test which was basically drive it and come back after 1000km's and they check the level. It used 8 litres in 3000 km's. Ford said they would replace the engine at 10,000 km's but it was using so much they ended up replacing it at 3,000 km's. I was dealing with Centre Ford in WA and they said it was the 2nd in Australia at the time that had this problem. The engine was sent back and inspected by ford for the cause but I never followed up on this. Anyways I had no problems with warranty and I really do hope you have the same outcome as me.
There is obviously a problem so make sure you get a new engine and try different dealers or go direct to ford Australia. I'm happy to help where I can so feel free to PM me if you need help as I could find out more from Centre Ford.
Dont mod anything until your situation is resolved and you're happy with the outcome.
Cheers.
