  • Member For: 18y 8m 28d
Finalllly getting around to doing my gauges (purchasing), just wondering on the oil pressure one, if I buy the mechanical model, will I require the following sender :
http://cgi.ebay.com.au/GAUGE-ADAPTOR-BA-BF...1QQcmdZViewItem
Or if I go the electrical one
http://cgi.ebay.com/ebaymotors/AUTOMETER-C...bayphotohosting
What else is required?
Thanks
Josh
https://www.fordxr6turbo.com/forum/topic/41433-oil-pressure-gague-sender-unit/
  • Abuser of Charvels
  • Member For: 21y 6m 17d
  jcooke said:
nobody?
Don't get a mechanical oil pressure gauge, get those two auction items you posted. The electric gauge has the sender and it connects to the adapter you posted, you need them both. The adapter can also be used for oil temp for an electric gauge.
  • Member For: 17y 8m 3d
hi there, the ebay auction you posted for the adaptor plate is actually mine ;) pm me for any questions, all forum members recieve less than trade discount from us cheers
  jcooke said:
thanks for that gene. Just wondering the model number of the gauges you used for the oil pressure? looks good.
I got my gauges from Scott, here: http://ozegauge.com.au
  • 3 weeks later...
  • Member For: 17y 5m 30d
hey do you still have those adaptor plates for the gauges? any instructions with it or am I better of givin it all to a auto elec?
kind regards
kind regards
Hey mate,
I didnt end up using the adapater plate, I just bought a T piece from the local Autobarn for like $10. The adapter as mentionned above does look very handy if you are going to be monitoring both oil temp and oil pressure. Which cobalt gauges did you install?
I have just finished the install of the ozegague gauges and it all went very smooth. If you post the wiring diagram for the cobalts, I'm more than happy to take a look and confirm that it needs the same wiring as mine. If so I'll write a howto now that its fresh in my memory. It really is a simple job to do. I'm a rookie myself when it comes to wiring but it is all pretty straight forward after I did some searching.
Cheers
Josh
