  • Member For: 21y 7m 24d
I have two blocks sitting at home but can't find any engine numbers on them.
One is a ba and one is a bf both have only got raised part numbers on them.
So do they have engine numbers stamped in them?
If so where?
cheers
https://www.fordxr6turbo.com/forum/topic/40660-engine-numbers/
  • Forged Member
  • Member For: 18y 3m 9d
can't remember where, but look for a Engine number that start with "JGSW" if its from a sedan, "JGAT" if its from a territory, "JGCM" if its from a ute" and "JGWA" if its from a wagon.
All 6cyl falcons have a VIN that starts with "6FPAAA", the 6cyl falcs engine numbers are the same as the VIN minus the "6FPAAA"
good luck
  • Forged Member
did you check both sides of the block, cos the picture shows you should look on the drivers side
I would've taken stealthxr's instructions as the passenger side, I don't know why...
