TURBO4LT Member 1,533 Member For: 21y 9m 14d Gender: Male Location: NSW Posted 14/09/08 01:03 AM Share Posted 14/09/08 01:03 AM Get your fuel system set-up and then check if the standard regulator has enough flow to keep the fuel pressure within the correct levels, sometimes with the increased flow of a 044 pump you will find that the return/regulator cant keep the pressures down and they will creep up. I just went through this and I know this is affecting other cars out there with 044 pumps going into the standard regulator you just don't know about it if pressures aren't checked. Link to comment https://www.fordxr6turbo.com/forum/topic/40560-siemens-injectors/page/2/#findComment-733611 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 25d Gender: Male Location: SW Sydney Posted 14/09/08 01:14 AM Author Share Posted 14/09/08 01:14 AM Thanks for the headsup frank, that could be the cavitation noises I get from the pump... (the whine changes pitch sometimes when its idling) Link to comment https://www.fordxr6turbo.com/forum/topic/40560-siemens-injectors/page/2/#findComment-733616 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 13d Gender: Male Location: Sydney NSW Posted 14/09/08 01:22 AM Share Posted 14/09/08 01:22 AM Be worth fitting a fuel pres' guage mate.If presure is going up and down then the tune will be all over the place Link to comment https://www.fordxr6turbo.com/forum/topic/40560-siemens-injectors/page/2/#findComment-733621 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 25d Gender: Male Location: SW Sydney Posted 14/09/08 01:56 AM Author Share Posted 14/09/08 01:56 AM I know the tune is solid, so I don't think its low on pressure, the afr's are in the mid-11's so its not extremely rich. We'll see what adam says when the dump goes on and we can get the full potential out of the motor and turbo Link to comment https://www.fordxr6turbo.com/forum/topic/40560-siemens-injectors/page/2/#findComment-733638 Share on other sites More sharing options...
