invisable Member 14 Member For: 17y 4m 16d Posted 11/12/07 12:32 AM Share Posted 11/12/07 12:32 AM hey guys,I have a problem, when I use my air-con water starts leaking from under the dash on the passenger side, it takes upto 30 mins to start but, also after using the aircon for a while when turning a corner you can hear water moving in the dashany ideas?thanks guys Link to comment Share on other sites More sharing options...
exarsixturbo Dr. Speed Member 784 Member For: 17y 5m 22d Gender: Male Location: The land of Politicians, Public Servants, Porno & Pyrotechnics Posted 11/12/07 01:13 AM Share Posted 11/12/07 01:13 AM Its an easy fix but you will need some special tools:A long weightA tin of compressionTwo skyhooksSome rainbow coloured paintA set of metric adjustable spannersA left handed screwdriverand a tin of scotch mist Link to comment Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 17d Gender: Male Location: Not sure? Posted 11/12/07 01:20 AM Share Posted 11/12/07 01:20 AM (edited) Your A/C core has a leak. If your car is out of warranty, I cry for you. Mine happened when the car was 2 years old. Whole dash out job. And the smell of coolant lasted for about 6 months too. It's a vile smell too. Edited 11/12/07 01:23 AM by ENVY-T Link to comment Share on other sites More sharing options...
invisable Member 14 Member For: 17y 4m 16d Posted 11/12/07 01:25 AM Author Share Posted 11/12/07 01:25 AM Its an easy fix but you will need some special tools:A long weightA tin of compressionTwo skyhooksSome rainbow coloured paintA set of metric adjustable spannersA left handed screwdriverand a tin of scotch mist so if I can find all of these tools that don't exist I should be able to fix it?is there any way of fixing it without these items? Link to comment Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 17d Gender: Male Location: Not sure? Posted 11/12/07 01:29 AM Share Posted 11/12/07 01:29 AM so if I can find all of these tools that don't exist I should be able to fix it?is there any way of fixing it without these items?Your A/C core has a leak. If your car is out of warranty, I cry for you. Mine happened when the car was 2 years old. Whole dash out job. And the smell of coolant lasted for about 6 months too. It's a vile smell too. Link to comment Share on other sites More sharing options...
exarsixturbo Dr. Speed Member 784 Member For: 17y 5m 22d Gender: Male Location: The land of Politicians, Public Servants, Porno & Pyrotechnics Posted 11/12/07 01:30 AM Share Posted 11/12/07 01:30 AM You can fix anything with the right tools... But if you can't find these ones, I would go with Envy's idea. Same thing happened to my old car! Link to comment Share on other sites More sharing options...
F6BF Member 438 Member For: 19y 1m 10d Location: Sydney Posted 11/12/07 01:39 AM Share Posted 11/12/07 01:39 AM I would check the drain hose, make sure that its not blockedU can get to it from under the car, located around the transmission tunnellHTH Link to comment Share on other sites More sharing options...
invisable Member 14 Member For: 17y 4m 16d Posted 11/12/07 01:47 AM Author Share Posted 11/12/07 01:47 AM thanks guys for the help, I did see your post envy but after I replyed to the 2nd post,thanks again Link to comment Share on other sites More sharing options...
cqae Member 229 Member For: 21y 2m 17d Posted 11/12/07 01:51 AM Share Posted 11/12/07 01:51 AM feel the water, if its warm, then suspect the heater core, if its cold most likely just the condensation from the a/c system-& the drain off tube might be blocked. it is supposed to gather water like that & drain it out under the car Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 11m 9d Gender: Male Location: Sydney Posted 11/12/07 01:52 AM Share Posted 11/12/07 01:52 AM People are too quick to be negative in diagnosing problems.If the water is fresh, with no coolant, then the problem is the drain host.As F6BF mentioned it is a little hose at the side of the transmission tunnel. It sometimes gets blocked or melted.If the water smeels like coolant, the it is a major job.If the car is under warranty, make it Ford's problem Link to comment Share on other sites More sharing options...
