  • Member For: 19y 6m 12d
Hey all,
Just about to pick up the new car (BF II Turbo in the new bodykit - Neo).
It has the OEM bluetooth kit in it, which I'll probably use a bit for the phone. Till now I have been using a Jabra Bluetooth headset.
Is it possible to pair both devices and decide when the phone rings which device to answer with?
E.g if you have people in the car....but want to have a more private call answer with the headset, or a less private call answer with the OEM car kit.
Is this possible? (My Bluetooth knowledge is still a little sketchy)
  • Member For: 21y 3m 9d
I do not think so, but it would be more dependant on what phone you have.
The only way to make sure is to give it a go.
My phone Imate Jasjam will not do it as it will only pair with one handsfree device and it will be first in first served.
  • Member For: 20y 4m 8d
From Memory - will check with the manual later.
The car will pair with up to seven phones. The last phone connected has priority for the next conncetion. If you and your wife carry phones, the kit will give priority to connect to the last phone connected in the car I.e. whoever drove the car last. Works well.
To switch the call to the handset - hold the car Bluetooth button down (there is only one button) until the call switches to handset.
If you want to play music through the Bluetooth you can, this is excellent to annoy the hell out Lexus owners - they can't do it
  • Bored Member
  • Administrator
  • Member For: 22y 6m 9d
And has nothing to do with the question.... :stupid: ....not that thats unusual round ere....
You can but you have to do it on the phone manually by choosing which device you wish to connect to at the time, meaning your eyes are going to be off the road for an awful long time...
Or you could set up two different profiles and use the different connections for each one then flick between the two as needed...
  • Sucker
  • Moderating Team
  • Member For: 21y 28d
:spit:
Like Zapper said it depends on your brand of phone as well. I have a Palm and it can be connected to two at once but you have to answer calls with the device and not the phone :secret:
It does indeed sound device dependant....I vaugley understand that there could be a handsfree and headset profile in the bluetooth and if the two devices were able to connect to different profiles they might both be able to be used.
I'll have a bit of a muck around over the weekend when I get the new car....apparently the new darker rims don't look too bad against Neo.
Thanks for the replys too.
