carazy Member 27 Member For: 17y 11m 3d Posted 30/11/07 10:31 PM Share Posted 30/11/07 10:31 PM Hey guys,Just put the generic tunes put on my stock XR6t Mark II BA. 8psi runs perfectly, so does 10psi actually. It's smooth and crap loads faster. I put it on the 8psi tune 2 days ago and the 10 psi tune last night. Can't hear any pinging and it really does run perfectly. Should I still gap the plugs down to 0.8mm? I don't know what they are at the moment but if it's running so well do I need to change anything. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 9m 13d Gender: Male Location: Sydney NSW Posted 30/11/07 10:33 PM Share Posted 30/11/07 10:33 PM Its a good idea to re-gap them as many cars run poorly onhigger gaps... but if its running ok then maybe they are already gapped correctly Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 1m 2d Gender: Male Location: Sydney Posted 30/11/07 10:34 PM Share Posted 30/11/07 10:34 PM If it aint broke....... Link to comment Share on other sites More sharing options...
carazy Member 27 Member For: 17y 11m 3d Posted 30/11/07 10:55 PM Author Share Posted 30/11/07 10:55 PM If it aint broke.......That's what I figure.. Might get it chucked on the dyno to check A/F ratio's otherwise.. I'll just leave it. More then happy with the power though. Now I just need to spend some money on suspension Link to comment Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 6m 2d Gender: Male Location: NSW Posted 01/12/07 10:53 AM Share Posted 01/12/07 10:53 AM I'd regap them.It's a small job for a bit of insurance.The increased boost blows the spark away and causes a misfire. The end result is bent rod/s.That happened to me and cost me an engine. Not a pleasant experience. Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 11m 9d Gender: Male Location: nsw Posted 01/12/07 10:57 AM Share Posted 01/12/07 10:57 AM I think the perfered gap is 0.89mm Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 6m 13d Gender: Male Location: Perff, WA Posted 01/12/07 11:10 AM Share Posted 01/12/07 11:10 AM and how does one gap the plugs??? Link to comment Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 6m 15d Gender: Male Location: Broady, Melbourne Posted 01/12/07 01:24 PM Share Posted 01/12/07 01:24 PM (edited) I'd regap them.It's a small job for a bit of insurance.The increased boost blows the spark away and causes a misfire. The end result is bent rod/s.That happened to me and cost me an engine. Not a pleasant experience.It also happened to me and to many others - look around. If you run generics without regapping and without sticking it on a dyno, you're taking a stupid risk. Spending a few bucks can potentially save you thousands. When I blew mine, I didn't hear any pinging either. I had the 10 psi in for no more than 45 minutes before it backfired under full throttle and bent 2 rods. If you do break it, expect to spend somewhere around 4k to get it back to stock.Dont forget if you do blow it and have to get a new motor, specify the Tzatziki injected variant as this is superior to the lesser Tabouli injection. The science lies in that Tzatziki lubricates the cylinders about 90% better than Tabouli, causing less friction. Edited 01/12/07 01:25 PM by straughsberry Link to comment Share on other sites More sharing options...
Guest EGOXRT Guests Posted 01/12/07 01:35 PM Share Posted 01/12/07 01:35 PM It also happened to me and to many others - look around. If you run generics without regapping and without sticking it on a dyno, you're taking a stupid risk. Spending a few bucks can potentially save you thousands. When I blew mine, I didn't hear any pinging either. I had the 10 psi in for no more than 45 minutes before it backfired under full throttle and bent 2 rods. If you do break it, expect to spend somewhere around 4k to get it back to stock.Dont forget if you do blow it and have to get a new motor, specify the Tzatziki injected variant as this is superior to the lesser Tabouli injection. The science lies in that Tzatziki lubricates the cylinders about 90% better than Tabouli, causing less friction.Get tzatziki with it!!! They say the NGK humus core plugs don't need gapping and are virtually "blow out proof".. Link to comment Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 6m 15d Gender: Male Location: Broady, Melbourne Posted 01/12/07 01:43 PM Share Posted 01/12/07 01:43 PM Get tzatziki with it!!! They say the NGK humus core plugs don't need gapping and are virtually "blow out proof"..OMG! Did the humus core come out yuleh? Sik. I'm getting 8. I'l drill a couple of extra holes in the head just to fit the extra ones yuleh. Link to comment Share on other sites More sharing options...
