RHR BOOST Moderating Team 5,698 Member For: 21y 4m 10d Gender: Male Location: Southern Highlands NSW Posted 02/12/07 02:36 AM Share Posted 02/12/07 02:36 AM Mate Im here your allay Ive had the same problem with a thumping noise coming from the front brakes. Mine went away after a while and never returned Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 4m 27d Gender: Male Location: Perff, WA Posted 02/12/07 10:59 AM Author Share Posted 02/12/07 10:59 AM well, thanks for the support robbo, I've sorted mine out now, but noone will EVER know what it was*insert evil laugh track* Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 6m 8d Gender: Male Location: The 8th Dimension Posted 02/12/07 11:10 AM Share Posted 02/12/07 11:10 AM The rotor should be held to the hub by two large screws, if they have come lose the rotor would move around like that. But as everyone has said once the wheel is on and the nuts are done up properlythere should be no movement at all.But some how I think there may be a loose nut behind the steering wheel. Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 4m 27d Gender: Male Location: Perff, WA Posted 02/12/07 11:25 AM Author Share Posted 02/12/07 11:25 AM cheers for that brad, you're a gentleman and a scholar (I assume)as I said I sorted the knock out, so that's no dramas. bt basically you're saying that there's no big problem with having the rotor floating that much?? as long as the wheel is on it'll be sweet (here we go...)CheersDan Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 6m 8d Gender: Male Location: The 8th Dimension Posted 02/12/07 11:29 AM Share Posted 02/12/07 11:29 AM No it should be tight against the hub. Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 4m 27d Gender: Male Location: Perff, WA Posted 02/12/07 11:52 AM Author Share Posted 02/12/07 11:52 AM right so... (forgive me brad, been to the pub!) wheels are on, nuts are tight, nuts hold wheel, wheels holds rotor, rotor holds... she'll be swoit as long as no movement when all is tight? Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 21d Gender: Male Location: Brisbane Posted 02/12/07 11:59 AM Share Posted 02/12/07 11:59 AM Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 6m 8d Gender: Male Location: The 8th Dimension Posted 02/12/07 12:08 PM Share Posted 02/12/07 12:08 PM (edited) On your disc brake there is a screw (Phillips head), it will be between two of the Studs this is what holds the disc to the hub. Edited 02/12/07 12:11 PM by seventytwo Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 21d Gender: Male Location: Brisbane Posted 02/12/07 12:15 PM Share Posted 02/12/07 12:15 PM And if you can't get to it with the wheel on you've done it wrong Link to comment Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 4m 27d Gender: Male Location: Perff, WA Posted 02/12/07 12:56 PM Author Share Posted 02/12/07 12:56 PM hmmm, I seem to be missing some screws... (anyone!?) are the screws a necessity brad? or will the wheel nuts be sufficient to hold the fort?or best to source some screws for it? Link to comment Share on other sites More sharing options...
