xr6turbo2nv Member 22 Member For: 18y 8m 29d Location: Gold Coast (Queensland) Posted 27/11/07 09:31 AM Share Posted 27/11/07 09:31 AM Hi can someone help as starting this week I cant turn on my cruise control and then I noticed that I had no brake light's. has anybody else had this problem and what did you do to fix it. its du for a service in another 1000ks so ill wait till then if I can. thanks johnboy Link to comment Share on other sites More sharing options...
PSYCHO XRT THE PSYCHO XRT Donating Members 1,275 Member For: 19y 3m 30d Gender: Not Telling Location: At the lights! Posted 27/11/07 09:33 AM Share Posted 27/11/07 09:33 AM First things first. Check your fuses?? Link to comment Share on other sites More sharing options...
exarsixturbo Dr. Speed Member 784 Member For: 17y 8m 6d Gender: Male Location: The land of Politicians, Public Servants, Porno & Pyrotechnics Posted 27/11/07 09:39 AM Share Posted 27/11/07 09:39 AM I second that... Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 12d Gender: Male Location: Victoria Posted 27/11/07 09:48 AM Share Posted 27/11/07 09:48 AM Blown fuse for sure. Link to comment Share on other sites More sharing options...
kinggee Member 28 Member For: 22y 3m 8d Gender: Male Location: Townsville, QLD Posted 27/11/07 09:49 AM Share Posted 27/11/07 09:49 AM (edited) Check to see if the light/cruise control switch on the brake pedal has come unclipped. Stick your head down with the pedals and look for the switch that is activated when you press the brake pedal (if your car is a manual there will be one on the clutch pedal as well). The switch turns (like a keyhole lock) to lock into the bracket.This happened to me earlier this year and this is what was wrong with it. Edited 27/11/07 09:57 AM by kinggee Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 11m 13d Gender: Male Location: Brisbane Posted 27/11/07 10:56 AM Share Posted 27/11/07 10:56 AM xr6turbo2nv said: .....its du for a service in another 1000ks so ill wait till then if I can.Without brake lights? Fark that! Link to comment Share on other sites More sharing options...
velociTy Team Velocity Member 1,202 Member For: 20y 6m 10d Gender: Male Location: Margs WA Posted 27/11/07 11:07 AM Share Posted 27/11/07 11:07 AM tab said: Without brake lights? Fark that!that's what I thought Link to comment Share on other sites More sharing options...
benmwhite Donating Members 143 Member For: 20y 10m 12d Gender: Male Location: Toowoomba Posted 27/11/07 11:21 AM Share Posted 27/11/07 11:21 AM cruise control will not engage if you have a blown or non-operational brake lamp - sounds fuse related... unlikely that you would have blown both brake lamps. Link to comment Share on other sites More sharing options...
Jordz xr6 fan Member 44 Member For: 17y 4m 20d Gender: Male Location: Melbourne Posted 27/11/07 12:54 PM Share Posted 27/11/07 12:54 PM My dads ute had a problem with the switch under the brake pedal that stopped the lights from working.We ended up putting some duck tape on the switch and fixed it for the time being.Driving in heavy traffic with a $50,000 boat on the back with no tail lights is risky business.I think it was $50 for a new switch.I have no idea about the cruise control. Link to comment Share on other sites More sharing options...
XR_Brute Member 120 Member For: 18y 6d Gender: Male Location: melbourne Posted 28/11/07 07:40 AM Share Posted 28/11/07 07:40 AM reset the switchs, this fixes them 90% of the time, all you need to do is remove both switch, pull the push rods all the way so theyre fully extended, then, with you hand pushing down the pedal, refit both switchs, release the pedal, and theyll click into adjustment, DONT pull up on the pedal, it'll undo your hard work Link to comment Share on other sites More sharing options...
