No Cruise Control And No Brake Light's
xr6turbo2nv
  • Member For: 18y 4m 8d
Hi can someone help as starting this week I cant turn on my cruise control and then I noticed that I had no brake light's. has anybody else had this problem and what did you do to fix it. its du for a service in another 1000ks so ill wait till then if I can.
thanks johnboy
  • Member For: 21y 10m 17d
Check to see if the light/cruise control switch on the brake pedal has come unclipped. Stick your head down with the pedals and look for the switch that is activated when you press the brake pedal (if your car is a manual there will be one on the clutch pedal as well). The switch turns (like a keyhole lock) to lock into the bracket.
This happened to me earlier this year and this is what was wrong with it.
Edited by kinggee
  • Member For: 20y 5m 22d
cruise control will not engage if you have a blown or non-operational brake lamp - sounds fuse related... unlikely that you would have blown both brake lamps.
  • Member For: 16y 11m 30d
My dads ute had a problem with the switch under the brake pedal that stopped the lights from working.
We ended up putting some duck tape on the switch and fixed it for the time being.
Driving in heavy traffic with a $50,000 boat on the back with no tail lights is risky business.
I think it was $50 for a new switch.
I have no idea about the cruise control.
  • Member For: 17y 7m 16d
reset the switchs, this fixes them 90% of the time, all you need to do is remove both switch, pull the push rods all the way so theyre fully extended, then, with you hand pushing down the pedal, refit both switchs, release the pedal, and theyll click into adjustment, DONT pull up on the pedal, it'll undo your hard work :P
