chalkie Member 18 Member For: 17y 8m 8d Gender: Male Location: Brisbane Posted 22/11/07 10:20 AM Share Posted 22/11/07 10:20 AM I have had an ongoing brake issue with my BF XR6T. When I reverse out of my drive way sometimes the front brake seem to grab and it can be felt through the steering and brake pedal. It has been back to the local dealer several times only to say it is carrying out a self test and it is nothing to worry about, well to me the brake are pretty important so has anyone else had similar fault or have any ideas. I thought all self tests where carried out on start up not as you were reversing am I wrong.Help. Link to comment Share on other sites More sharing options...
obi Member 150 Member For: 18y 10m 4d Location: Qld Posted 23/11/07 04:32 AM Share Posted 23/11/07 04:32 AM I think your Dealer is talking through his hat. If it's under Warranty take it to another dealer, if not a Brake Specialist ! It shouldn't do it. Link to comment Share on other sites More sharing options...
pilko80 Inactive Members 1 Member For: 17y 6m 22d Posted 02/12/07 01:05 PM Share Posted 02/12/07 01:05 PM I think you'll find that the ABS carries out a self test the first time your speed goes above say 5kph once it has been started. (ie, when you start the car and reverse out the drive)It's more noticeable in some cars than others. I remember 2 identical cars that I drove, and one was much more noticeable than the other. I was quite concerned until someone told me what it was, then it made sense... Now I like hearing/feeling it (and then no ABS warning light!) as I know that the ABS/braking system has tested itself and considers itself working.The amount you feel it through the pedal and body of the car will depend on many things, one being the clearance of the metal brake lines to the body of the car.It shouldn't actually be applying the brakes (well, you shouldn't feel the car slow down) and should last for less than a second. If its actually stopping or slowing the wheels, then get it checked out.Cheers Link to comment Share on other sites More sharing options...
Tyson1 Member 4 Member For: 21y 11m 4d Posted 11/06/08 11:53 PM Share Posted 11/06/08 11:53 PM I have a 2003 XR6T Ute, It recently has started this problemLarge vibration through thr pedal when braking at slow speeds & ABS fail light has engaged on Two occasionsDoes usually occurs just after start up, Backing out & the garage & braking at the kerbBut also occrs after drving for a while alsoDid anyone get a solutionCheers Link to comment Share on other sites More sharing options...
howitzer85 Member 241 Member For: 18y Gender: Male Location: The marsh... Posted 25/11/08 11:19 AM Share Posted 25/11/08 11:19 AM I have a 2003 XR6T Ute, It recently has started this problemLarge vibration through thr pedal when braking at slow speeds & ABS fail light has engaged on Two occasionsDoes usually occurs just after start up, Backing out & the garage & braking at the kerbBut also occrs after drving for a while alsoDid anyone get a solutionCheersI've got the same problem - feels like the abs is kicking in on really light braking when comming to a stop, I can feel it thru the pedal and hear the abs unit working.its only just started after having the car lowered.I'm guessing one of the wheel speed sensors is buggered and at slow speed the ecu thinks the wheels are locked up and turns the abs on...does this sound possible????I've checked brake operation and they still work fine its just when I'm comming to a stop <10km/h...thanks. Link to comment Share on other sites More sharing options...
Tyson1 Member 4 Member For: 21y 11m 4d Posted 02/12/08 02:00 AM Share Posted 02/12/08 02:00 AM They finally found the problem third time upFaulty ABS sensor All fixedJust sent it in for a service todayBeen told new brake pads & rotors need skimming again, only done 14,000km since last skim & set of padsThey pretty much said get used to it ever 10,000km Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 7m 29d Gender: Male Posted 02/12/08 02:18 AM Share Posted 02/12/08 02:18 AM no way should pads and rotors last that short, even in an auto.I punished my rotors and pads and they lasted like 50k, with some meat left!!I found ferodo formula pads worked well with the stock rotors, that's what I had. Link to comment Share on other sites More sharing options...
