falcon73 Member 163 Member For: 18y 9m 16d Posted 22/11/07 05:12 AM Share Posted 22/11/07 05:12 AM What does a BA Ghia V8 falcon have as a diff is it a m78 like the N/A 6 or is it a m86 like the turbos, and can you put a m78 centre into a m86 dif housing(probably not) but thought I would check as stranger things have happened Link to comment https://www.fordxr6turbo.com/forum/topic/40015-m78-or-m86-diff/ Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 22y 4d Location: Geelong Victoria Posted 22/11/07 11:24 AM Share Posted 22/11/07 11:24 AM Pretty sure all V8's and turbos had the M86. Link to comment https://www.fordxr6turbo.com/forum/topic/40015-m78-or-m86-diff/#findComment-599183 Share on other sites More sharing options...
CrankR Member 3 Member For: 17y 7m 18d Posted 30/11/07 11:09 PM Share Posted 30/11/07 11:09 PM How do u tell?Is it written on them?Ta,CrankR. Link to comment https://www.fordxr6turbo.com/forum/topic/40015-m78-or-m86-diff/#findComment-602843 Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 22y 4d Location: Geelong Victoria Posted 01/12/07 12:47 AM Share Posted 01/12/07 12:47 AM Ford diffs usually have a small metal tag on the bottom of the diff centre, apart from that I don't know how else you can tell bar the physical size of them. The 78 is 7.8 inches the 86 8.6 inches, with that being the size of the diff centre. Link to comment https://www.fordxr6turbo.com/forum/topic/40015-m78-or-m86-diff/#findComment-602883 Share on other sites More sharing options...
Brad.R Member 47 Member For: 17y 8m 29d Gender: Male Location: Perth Posted 04/12/07 02:03 PM Share Posted 04/12/07 02:03 PM here is something that you might find useful 1 Link to comment https://www.fordxr6turbo.com/forum/topic/40015-m78-or-m86-diff/#findComment-604615 Share on other sites More sharing options...
falcon73 Member 163 Member For: 18y 9m 16d Posted 11/12/07 02:27 AM Author Share Posted 11/12/07 02:27 AM So if I get diff gears from a Borg warner M78 diff centre, like higher gears they would bolt to the centre OK or if I got a centre from something like a B/W that has the m78 model number it should bolt straight in. Link to comment https://www.fordxr6turbo.com/forum/topic/40015-m78-or-m86-diff/#findComment-607140 Share on other sites More sharing options...
-frosty- Member 27 Member For: 17y 10m Gender: Male Posted 01/02/08 10:49 PM Share Posted 01/02/08 10:49 PM so the m86's are LSD? how hard would it be for me get get a m86 on my n/a 6? Link to comment https://www.fordxr6turbo.com/forum/topic/40015-m78-or-m86-diff/#findComment-629010 Share on other sites More sharing options...
falcon73 Member 163 Member For: 18y 9m 16d Posted 03/02/08 02:36 AM Author Share Posted 03/02/08 02:36 AM M86 into a m78 or n/a 6, you need whole diff centre housing driveshafts not sure on the brake backing plates, as the m86 is larger Link to comment https://www.fordxr6turbo.com/forum/topic/40015-m78-or-m86-diff/#findComment-629507 Share on other sites More sharing options...
