MiKa Donating Members 4,243 Member For: 18y 7m 11d Gender: Male Location: Melbourne, VIC Posted 16/11/07 08:59 PM Share Posted 16/11/07 08:59 PM Ok guys this has been doing my head all morning.....What is torque?... I was talking to a guy at work and he seems to think having lots of torque doesnt make a difference, for example down the quarter. He reckons that its your rwkw that makes the car fast.... I believe him in a sence cause look at the rice burners they dont seem to make much torque but they are quick.. What is the difference between outright power (rwkw) and torque in a 'practical' sence??Hope someone clears my head soon...Cheers Mike Link to comment Share on other sites More sharing options...
Guest bluprinturbo Guests Posted 16/11/07 09:49 PM Share Posted 16/11/07 09:49 PM the old saying torque wins races kws sells cars is true.ricers would still have decent torque if there running heaps of boost.torque is the twisting power of the engine.the more torque the quicker you offset the weight of the car. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 10m 12d Gender: Male Location: Sydney NSW Posted 16/11/07 10:31 PM Share Posted 16/11/07 10:31 PM What makes our cars fast it torque. You need big torque to move a heavy car and get it off the line.Torque is generally what the motor produces down low, and usually max's out around 4500.If you look around at a few dyno graphs on here you'll see some cars are tuned with alot more torque than others but all may end up with similar peak power results... like, they all say 300wkws but have a completely different looking curve on the graph.More torque can feel like a lag free tune compared to the same peak power (300wkws) on a car with less torque, which is why some poeple think they have laggy tunes. They just have less torque tuned in ( safer on rods! ) so when top end power hits, there is a bigger difference compered to down low in the torque range.A good example of torque, is over taking on the freeway in 5th or 6th and having it pull strongly... a 200sx with 300wkws wont do that due to its much reduced torque. 1 Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 25d Gender: Male Location: SW Sydney Posted 16/11/07 10:44 PM Share Posted 16/11/07 10:44 PM a good thing to remember is that torque gets you moving, and power (kw) is what keeps you there! Link to comment Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 7m 11d Gender: Male Location: Melbourne, VIC Posted 16/11/07 10:56 PM Author Share Posted 16/11/07 10:56 PM Thanks for the info dudes clears it up heaps.... I did google it and your responses mirror what I have found out... So my 650nm of torque is what makes my 227rwkw T 'feel' so quick ey!! Link to comment Share on other sites More sharing options...
aiboart Member 665 Member For: 20y 2m 17d Posted 16/11/07 10:57 PM Share Posted 16/11/07 10:57 PM Mike,KW is how fast you can accelerate you car for a given weight.Torque is a force or push, in a circle - it is half the picture.This is the difference between KW and torque.Imagine accelerating of a trolley of a certain weight and you are the engine – you are pushing.For any given power output you can.1 -Do a few big pushes infrequently.(In a car engine this is high torque low revs.)2- Do lots of little pushes frequently.(In a car engine this is low torque high revs)That’s it. Your power output and the weight of the trolley determine the acceleration.Some other pointsGears are levers, in circles. Levers allow you to change a fast little push into a slow hard push, and visa versa.Gears do the same in circles, they allow you to change a high rpm low torque to low rpm hi torque.So the rev monster and the torque monster can produce the same KW. The rev monster makes half the torque but twice the revs of the torque monster.The RWKW for any rear wheel speed is also the same, the gearing is different.Some more point.In an acceleration run the car motor is constantly changing speed - which is obvious.A complexity is that nearly all car motors constantly change max torque with RPM - which is not obvious. The factory tune XRT is one of the new breed low boost types that don’t - the 335i/135i is another. Their torque curves at max throttle and full boost are flat - straight lines. In many ways this is the ideal for an everyday car. If your torque varies with RPM this means that in any given gear, the cars the acceleration is constantly changing with RPM – you experience this as a a surge of acceleration. So whilst you may have a great torque spike at a certain RPM, where the acceleration is staggering, the moment you move your RPM away from that spike your acceleration drops. The racer comment about torque winning racers is speaking to how complex and difficult it is for a driver to keep a particular engine spinning where the torque is high, at just the right speed, just when you want it. An engine may produce staggering power, but is it spinning at 8,000 rpm when you launch... A simple way to work out the average power of your car in a run, in a particular gear, is to look at the area under the torque curve the RPM range of interest. Regards,aa 1 Link to comment Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 7m 11d Gender: Male Location: Melbourne, VIC Posted 16/11/07 11:08 PM Author Share Posted 16/11/07 11:08 PM aiboart.... thank for the extra info... I had to read it a few times hehhe but im understanding it... Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 18y 2m Posted 17/11/07 07:14 AM Share Posted 17/11/07 07:14 AM well most of you seem to take alot of words to explain it, and you miss the point. so here it is...torque is the TURNING force applied to the crank. it is this force that is transmitted thru the driveline to the wheels and gives you acceleration that you can feel by PUSHING YOU BACK IN THE SEAT or the ability to spin the wheels.RWKW can be simplified as torque mulitiplied by RPM. Therefore (simplified) it is how many times per minute, a given amount of torque can be applied. An engine with high KW therefore must maintain as much torque for as long as possible as high into the rev range as possible to achive a high RWKW. its no good to make massive torque for a short rev range (like a prime mover truck) and likewise, you cannot achive big RWKW with lots of revs and no torque (like in a high revving motorcycle engine) - you need both. A piston engine inherrantly has a rpm point at which its ability to generate toque starts to diminish and continues to do so the harder it revs...so, RWKW is also total POWER because its a measure of BOTH, and ultimatley defines how fast you can accelerate a given mass. Link to comment Share on other sites More sharing options...
Guest dico2020 Guests Posted 03/06/08 12:12 PM Share Posted 03/06/08 12:12 PM I like torque.. its simple. ok torque for dummies so torque = kw x 9550 divided by rpm . roger that captains??ok so say a rota makes peak power of 400fwkw at 8000 rpm ---- 400x9550/8000 = 477.5nmxr6t makes peak power of 400fwkw at 5000rpm -----400x9550/5000 = 764nmstock xr6t makes 240fwkw at 5400rpm------------- 240x9550/5400= 424.444nmbig ole diesel truck has 300fwkw@1500rpm--------------- 300x9550/1500=1910nmsound about right??please note, I dont have an effn clue where a stock t makes its peak power. Link to comment Share on other sites More sharing options...
Guest dico2020 Guests Posted 03/06/08 12:22 PM Share Posted 03/06/08 12:22 PM Thanks for the info dudes clears it up heaps.... I did google it and your responses mirror what I have found out... So my 650nm of torque is what makes my 227rwkw T 'feel' so quick ey!!ok so ummmm 227 + 22% = 272.4 so im guessing mabey your dyno sheet says you made peak power at 4002rpm?? (using the 22% rule anyway) Link to comment Share on other sites More sharing options...
