dooda Member 10 Member For: 17y 8m 14d Posted 29/11/07 06:29 AM Share Posted 29/11/07 06:29 AM Hi guys, I think I might have an answer for you. we get brake squeal at work a lot. 90% of the time the squealing is from the pads resonating or vibrating against the metal caliper. The easiest way to fix it is buy a can of spray on anti squeal, remove the pads from the caliper and clean the back of the pads ( you will see the worn circle in the back of the pad where it has been rubbing againts the caliper). Then spray the back of the pads with the anti squeal (usually blue and very sticky). You just whack it back together and drive. Guarantee it will fix it. The water method works because you are basically lubricating between the pad and caliper which works for a period until it dries off and then its squeal time!!!Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/39822-noisey-brake/page/3/#findComment-601983 Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 9m 15d Gender: Male Location: Perff, WA Posted 29/11/07 06:33 AM Share Posted 29/11/07 06:33 AM hey thanks dooda, greatly appreciated mate! is this easily enough done @ home? like up on stands? or needs to be done in workshop?sorry to hijack Russ!cheersDan Link to comment https://www.fordxr6turbo.com/forum/topic/39822-noisey-brake/page/3/#findComment-601985 Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 9m 15d Gender: Male Location: Perff, WA Posted 29/11/07 09:28 AM Share Posted 29/11/07 09:28 AM ok, I don't have the energy or follow-through at the moment to do what dooda has suggested, but I did pull the wheels off and give the whole caliper and disc assy the blasting of a lifetime with some brake cleaner stuff... AND IT WORKED!!!!! for now at least, but YAY, quiet driving. Russ, give this a go if you're still having dramas.Dan Link to comment https://www.fordxr6turbo.com/forum/topic/39822-noisey-brake/page/3/#findComment-602057 Share on other sites More sharing options...
dooda Member 10 Member For: 17y 8m 14d Posted 29/11/07 11:35 AM Share Posted 29/11/07 11:35 AM no worries, interesting to see how long it lasts. Link to comment https://www.fordxr6turbo.com/forum/topic/39822-noisey-brake/page/3/#findComment-602128 Share on other sites More sharing options...
rhysy_boi Member 83 Member For: 18y 10m 20d Gender: Male Location: Perth, WA Posted 30/11/07 02:53 AM Share Posted 30/11/07 02:53 AM anyone tried the tubes of PBR anti-squeal you can buy? I will have a look at how to install it when I'm at the shops today. Rhys Link to comment https://www.fordxr6turbo.com/forum/topic/39822-noisey-brake/page/3/#findComment-602344 Share on other sites More sharing options...
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 17y 9m 15d Gender: Male Location: Perff, WA Posted 30/11/07 04:19 AM Share Posted 30/11/07 04:19 AM no haven't seen that one ryhs, but let us know how you go. Dan Link to comment https://www.fordxr6turbo.com/forum/topic/39822-noisey-brake/page/3/#findComment-602383 Share on other sites More sharing options...
