Mals BA XR6T Member 381 Member For: 22y 6m 6d Location: Sydney Posted 25/06/03 02:03 AM Share Posted 25/06/03 02:03 AM Fordboy, It's been back to the dealer about 6 times. I use my car for work, Taxi's are expensive when your using them alot, and also a day off work because the car is in a Ford Service Centre 100k's away from where I had to be, costs me a days payFord won't fix the windscreen noise until I can tell them where exactly it's coming from! It's driving me nuts, cause sometimes it's there at 100kph, and sometimes not!! (Sometimes not till 120kph) Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-31387 Share on other sites More sharing options...
Guest DEAN05 Guests Posted 25/06/03 06:56 AM Share Posted 25/06/03 06:56 AM just frony disc and pvc hoses Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-31511 Share on other sites More sharing options...
Gareth Member 71 Member For: 22y 5m 1d Posted 30/06/03 08:01 AM Share Posted 30/06/03 08:01 AM Mal, I had the same windscreen noise issue. If you put a bit of tape (I used duct tape) across the whole top of the screen, covering the gap between screen and roof, the noise will go away. They fixed my car by putting a rubber mould into the gap between the top of the windscreen and the roof. You could do the same thing by filling the gap with silicone, but why should you fix Fords design fault?It is a really easy fix.Good luck! I suggest you've had most of your problems now and from here on it's smooth driving! Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-32660 Share on other sites More sharing options...
chrislak Donating Members 400 Member For: 22y 5m 14d Location: Sydney Posted 30/06/03 10:31 AM Share Posted 30/06/03 10:31 AM I've had a few teething problem but 14 would drive me a bit Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-32700 Share on other sites More sharing options...
sixfan Flaccid Member Donating Members 2,503 Member For: 22y 19d Gender: Male Location: NOONAMAH, go figure..... Posted 01/07/03 12:32 AM Share Posted 01/07/03 12:32 AM 1 stones in sideskirt.that's it.I must be lucky! Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-32828 Share on other sites More sharing options...
Macktheknife Xtreme Xalted Member Donating Members 3,112 Member For: 22y 1m 3d Gender: Male Location: BrisVegas Posted 01/07/03 06:18 AM Share Posted 01/07/03 06:18 AM Not too much from me,Missing tweeters in the A pillers, slowly leaking coolant,just starting to get the brake shudder, (at 7500 km) heat shield vibration (twice), all fixed or 2B fixed at next opportunity. No questions at all from the dealer. Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-32908 Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 7m 30d Gender: Male Location: Sydney Posted 08/07/03 05:21 AM Share Posted 08/07/03 05:21 AM 2800km's and I have beaten your record.1. Pulsing when in Reverse Gear2. Change from 1st - 2nd, 2nd - 3rd and down again very very rough. I have driven about 4 auto turbo's and mine is the only one with this problem3. Alternator / Turbo whine comming through rear speakers above 2500RPM4. Oil was at the low mark at 2200kms5. Front drivers side blinker not working6. Drivers side C pillar broken when Mobile car kit antenna was installed by the dealer7. Interference between mobile phone and stereo when phone is in cradle (installer said it is not normal)8. Front passenger seat base moves back and forth when accelerating and braking9. Brake shudder10. Whistle from sunroof over 90km/ph11. Rattling noise when idling12. Car has stalled on me 4 times since picking up, 3 times was in reverse gear13. Different scratches on the body noticed at the dealer before I picked it up14. Tint on the sunroof scratched15. Metal above drivers side rear lights bent from factory16. Weird idling, sounds like its choking sometimesI have GADAN booked in for two days next week. That is going to be complete hell.... Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-34530 Share on other sites More sharing options...
Redhawk ....Time to lay this fairytale aside...... Donating Members 2,657 Member For: 22y 2m 30d Gender: Male Location: In the Ferry on the River Styx, not getting out just yet! Posted 08/07/03 07:46 AM Share Posted 08/07/03 07:46 AM Mals BA XR6T said: Ford won't fix the windscreen noise until I can tell them where exactly it's coming from! It's driving me nuts, cause sometimes it's there at 100kph, and sometimes not!! (Sometimes not till 120kph)Mal,I can't believe your dealer is stalling on the windscreen, what pr!cks. There is a seal insert they use now across the top of your windscreen (that's where the noise is generated). Someone posted a photo of it, looks good. Cheap, easy fix.The noise is caused by the eyrathane bead under the screen is too thin, my fix involved taking the original screen out, running a thicker bead of eyrathane and putting a new screen in (choice ), problem solved, but the insert is probably the standard Ford fix now.Hope you can get the problem sorted out mate, its worth pushing them, as the noise really p!ssed me off, big time Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-34556 Share on other sites More sharing options...
Mondie Firm Member Donating Members 2,924 Member For: 22y 7m 8d Location: Adelaide Hills Posted 08/07/03 10:38 AM Share Posted 08/07/03 10:38 AM Gadan sounds like he needs to take a couple of aspro and have a good lay in. BTW why is he called GADAN? Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-34585 Share on other sites More sharing options...
Guest MKeily Guests Posted 08/07/03 11:57 AM Share Posted 08/07/03 11:57 AM Gareth said: Mal, I had the same windscreen noise issue. If you put a bit of tape (I used duct tape) across the whole top of the screen, covering the gap between screen and roof, the noise will go away. They fixed my car by putting a rubber mould into the gap between the top of the windscreen and the roof. You could do the same thing by filling the gap with silicone, but why should you fix Fords design fault?It is a really easy fix.Good luck! I suggest you've had most of your problems now and from here on it's smooth driving! I don't believe you should use silicone to seal. I recall on the XE's it used to cause corrosion. Link to comment https://www.fordxr6turbo.com/forum/topic/3960-my-xr6t-at-ford-today/page/2/#findComment-34607 Share on other sites More sharing options...
