RHR BOOST Moderating Team 5,698 Member For: 21y 5m 15d Gender: Male Location: Southern Highlands NSW Posted 07/11/07 05:24 AM Share Posted 07/11/07 05:24 AM Oh my god, you VL flutter go buy a bloody VL, we have a reputation to keep you know.Elitist Ford snob Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 2m 21d Gender: Male Location: Melbourne Posted 15/01/08 07:26 AM Share Posted 15/01/08 07:26 AM Can anyone direct me where I can read how to block the stock BOV on an F6?Thanks Link to comment Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 17y 10m 4d Gender: Male Location: Sydney Posted 20/02/08 03:10 AM Share Posted 20/02/08 03:10 AM Can anyone direct me where I can read how to block the stock BOV on an F6?Thanks Take the small hose of the BOV and shove a screw in to the hose. Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 5m 15d Gender: Male Location: Southern Highlands NSW Posted 20/02/08 08:36 AM Share Posted 20/02/08 08:36 AM That sounds like the quick wayIf you want to get rid of it all together ..... Go to bunnings and get 2 1 inch leg rubbers for a chair.Loosen the clamp on the inlet side of the turbo. Loosen all four clamps at the cross over pipe. Remove the two nuts behind the cross over pipe (10mm) remove the BOV vacum pipe and then your cross over should come off.Now you will need a big arse pair of pliars to remove the BOV piping off the cross over pipe. ( turn the cross over pipe up side down so the "turbo intercooled is on the ground) Fit leg rubbers over the holes from that the BOV pipe once used. Re used the clamps and fit them back over the leg rubbers and do the first paragraph in reverse Link to comment Share on other sites More sharing options...
ETM Member 1,194 Member For: 17y 11m 7d Gender: Male Location: syd south Posted 20/02/08 08:54 PM Share Posted 20/02/08 08:54 PM just put a 1 way valve in the vac line that runs to the bov.that way the boost holds it shut when you are giving it some but the vacuum cant pull it open when you back off.works perfect Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 7m 12d Gender: Male Location: OZ Posted 21/02/08 02:46 AM Share Posted 21/02/08 02:46 AM (edited) just put a 1 way valve in the vac line that runs to the bov.that way the boost holds it shut when you are giving it some but the vacuum cant pull it open when you back off.works perfectThe std bosch valve is reverse vented therefore there is no point doing this. Boost acts against the side of the piston not the bottom therefore it opens under vacuum only.You can do what dule mentioned on std boost. Edited 21/02/08 02:47 AM by IH8TOADS Link to comment Share on other sites More sharing options...
