Hyena Member 61 Member For: 18y 3m 25d Posted 27/11/07 11:27 PM Author Share Posted 27/11/07 11:27 PM No it does it at different temperatures, I usually run around half way on the temp gauge and it does it there too but I first notice it on one stretch of road from home where I end up cruising along. Link to comment Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 18y 7m 26d Posted 21/03/08 02:04 PM Share Posted 21/03/08 02:04 PM have u noticed that it happens when it goes from a cold start to nearly warm, then all day its ok untill u have a cold start again.im thinkng around 1/4 temp.Yes this issue is a fu*king pain in the arse!!!My car does exactly this most the time and am temped to gap the plugs back to standard just to see if they are wholey and soley the cause of this annoying problem! I noted in this thread that C&V have informed a customer the closed up plug gaps are the cause ... do other tuners concur with this assumption?As soon as Blueboost fitted the Nizpro stage II kit to my stock 10,000km BF Typhoon the miss at idle arose straight away despite lifting the idle speed slightly several times since it still fuc*ing persists.BFhoon did you ever resolve the miss at idle you describe above?CheersJustin Link to comment Share on other sites More sharing options...
